hey guys,
So begins my a long journey to be. I was looking around for a r32 for a while as i had had enough of my e30 bmw and it's never ending issues. Saw this come up on carsales one morning and jumped on it 155000 genuine kms, apexi catback with muffler removed, Tein Super Streets, Volk Gtp's, Greddy turbo timer, Gay raceboi momo steering wheel, Cooling pro front mount, hks pod filter, Super cold A/C, Nismo 550cc injectors, gfb valve which i believe is leaking, Picked it up for the handsome sum of $6000 with 6 months rwc and rego, I drove it up from Brisbane Easter sunday.
Man what a trip dropped into limp home mode twice and popped a front tyre. Got home and found 3 boost clamps loose. So fitted 3 new ones and bolted down the hard pipe. While i was looking around found the fuel pump regulator hose was off so there was another boost leak, the charcoal canister lines were also not bolted up. Previous owner was a pilot in training and had no mechanical idea!!!! Car was bogging down from time to time so i pulled the afm and cleaned it and no more limp home mode YAY!!! Car still bogs down from time to time when going from full throttle to part so i'm thinking bov is leaking. So far im loving it. Fitted 2 new 215/45/17 eagle f1's to the front since i had to replace the popped one with a 235 and it was rubbing. So anyway ON WITH THE PICS
https://www.sau.com.au/forums/topic/362853-r32-project-streettrack/
Yeah mate enjoying it so far. Got a few mods planned, getting rid of the hks pod and gettng a apexi dual intake with a cai box. Full service, new pads, new rotors, stainless lines, new coil packs, ebc, new bov, new front pipe/high flow cat and wideband.
Edited by beemae30
Resoldered the afm joints today.... Definetly reccomend it to everyone made a heap of difference. Also stripped the bov wet n dryed it and re lubed it. Helped with the fluttering. Gave it a service with some motul 8100 excess as the old oil was FILTH. New fuel filter and all new fuel hoses. Covered the cross pipe over the radiator with reflective heat tape from work. Don't notice a difference but cleans it up as the old one was tarnished.
Edited by beemae30
Found my cooler was rubbing on my front bar from the shit install job the P/O did. When i pulled it off and had a look i found a lovely suprise. Cooling Pro Coolers ARE SHIT.
IMG_0443.jpg Don't know how u dint an inner fin like that but they did it.
IMG_0442.jpg It leaks oh well solder it up.
IMG_0440.jpg Score 550 yen
IMG_0436.jpg This stuff is awesome
IMG_0435.jpg Awesome tyre fitters
  • 3 weeks later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
