hi putting up my 32 as ive just finished building it
i got it with a turbo 25 in it off a so called "mate"
then when i did a compression test found out it had a piston with 70psi compression so the game began
decided to go a little different direction than most
also have it for sale
Engine:
RB25DE series 2 with 120000ks
Exhaust:
Suspension:
NRG adjustable coilovers
adjustable castor rods
Wheels:
17x9.5 +18 drift teks
painted white with rainbow flec
Modifications:
MICROTECH ltx12 stand alone ecu with hand controller
greddy style front facing plenum
80mm throttle body with s14 throttle cable to suit
turbo injectors
DRIFT fuel pressure reg
TURBOSMART fuel pressure gauge
1 intank fuel pump with 2 external pumps and a surge tank in boot
DRIFT pod filter with hard pipe very short intake
heavy duty clutch
52mm alloy radiator
TOMEI short shift kit
HID head lights
front head lights on toggle switch
battery relocated
turbo timer
digital volt meter
hicas removed
abs removed
s14 brake master and lines
gtst turbo brakes and 5 stud all round as it was a turbo shell
CUSCO 5 point bolt in half cage
slotted front rotors
front strut brace
side skirts and rear pods
recaro copy bucket seats
NARDI steering wheel
MOD PLATED FOR
rb25 engine
rb25 box
bolt in cage
bucket seats
2 seater
surge tank
external fuel pumps
turbo upgrade (from when it was a turbo car)
front mount (from when it was a turbo car)
Estimated Power:
car just made 170hp atw on the dyno with a safe tune with stock exhaust tuner said it should be capable of round 200hp with rev limiter raised and larger exhaust as the stock exhaust was very restrictive it now has extractors and a straight thru 3inch system (tuner recommended 3inch as of the sizeof intake etc)
dyno printout pretty much just goes up in a straight 45 degree angle so is awesome and responsive
and the important thing -chirps into 3rd gear even when changing at about 5000rpm ;)
just some photos taken on my phone sorry for the quality
thanks
https://www.sau.com.au/forums/topic/362865-r32-with-rb25de/
Love it... are you keeping it NA? If I was a p plater (in a non turbo p plater state) this is almost exactily what I would drive...
Will you be looking for more power and mid range torque?
Buy the way, this set up would be peeeeeeeerfect for nitrous... Single point, 75hp shot, nice and easy. Perfectly legal to have set up in your car, just cant have it hooked up on the street.
Also the greddy intake manifold has quite short runners. Maybe have a look at getting a spacer made up that bolts inbetween the head and the manifold to lengthen the runners for a little more low to midrange power.
Cheers
Justin
https://www.sau.com.au/forums/topic/362865-r32-with-rb25de/#findComment-5792817
Looking good, looking at doing similar mods to my car eventually.
XRATED he said it's for sale so he's probably keeping it NA until it says I would assume haha.
Is the car in NSW or QLD? How much are you looking at getting for it?
https://www.sau.com.au/forums/topic/362865-r32-with-rb25de/#findComment-5794187
nar i just bought the plates ;)
did all the work on the car with a mate
got it as a 32 with a low compression engine and did the conversion and built it up
it has pretty good power the whole way thru the rev range really
we were thinking maybe a 75 shot but aswell haha
looking at around $12000 as is
cars qld rego
thanks for all the positive comments ppl :)
https://www.sau.com.au/forums/topic/362865-r32-with-rb25de/#findComment-5801510
