Hey guys, just starting to do up my r33, pulled front kit off, pulled intercooler off, takin headlights off so far. looking at working on it DIY to turn it into my pride and joy. Details of the car include, blows blue smoke at startup and after idling for 10 mins, front kit needs re-fibreglassing and spraying, would like to get a turbo rebuild, want to strip the interior and fix little creeks n other noises, left headlight leaks water and blows globes, oil in intercooler pipes (not much but a little bit), stupid noise comin out of dash (only at startup or when i put air conditioner on- something to do inside the vents?), needs a power steering fluid reservoir, I live near Gawler in SA, got no idea where to start or where some good places to get work done are. Any help would be appreciated :) thanks guys
https://www.sau.com.au/forums/topic/362881-93-r33-project/
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
