I'm in the process of getting my R33 S2 Rb25 tuned with nistune on a std R33 ECU. When we put it on the dyno yesterday, the graph showed a sudden loss of power at about 5000 rpm or 160km/h in 4th, with the car reving noticeably slower and occasionally backfiring. We wern't able to tune it out, the best we could get it was to stay flat from 5000rpm onwards, but this required a noticeable jump in ingnition timings around that rpm i.e. 17-18-18-21-23-24 ect. Highest power reading we had was 210KW
Uploaded with ImageShack.us
The car has the following modifications
FMIC
3" exhaust
Hi flowed hypergear turbo @ 14psi
Z32 AFM
GTR fuel pump
Spark plugs are R5671A-7 gaped to .7 . I have investigated the coils before while experiencing rich and retard and have coated them in high temp silicon, but i could never find any cracks, or see any sparks in the dark.
Boost started at 14psi and gradually dropped to 12psi by redline.
Any ideas for whats causing this drop off in power?
What cat?
Done a run without exhaust?
Double checked base timing etc?
Cam belt isn't out a tooth?
Boost drop means actuator might not be setup right?
Are the plugs iri? You sure they are ok? (in future use coppers please!)
That's enough to start.
This.....
Cannot be
Correct.
OP, your options are;
1. R32 CPU without VCT, or with an external VCT controller
3. Z32 CPU
Nistune does NOT support the R33 ECU. So which ECU do you really have?
Looks like this sort of behavior:
Above was from worn valve springs and valves. That dip could not be controlled by timing or fuel, the depth of the dip is random.
Also you are likely to need high pressure actuator to hold boost steady up top.
The car is being tuned using an ostrich emulator on the R33 std ECU which will then be burned to a permanent chip once finished. Tuned by toshi who has done many cars on here this way
I believe the cat is a high flow, but it was there when i purchased. I've had it off before and its definatly 3" and you can see through it with a spiral type alloy fins inside
I did not do a run without the exhaust
Base timing was checked and is correct at 15 degrees
Have not checked cam belt, but have not touched it either
The plugs are copper, and have only done about 5000km, but this will be the first thing i change.
As for wastegate problems, the boost drop is very gradual, and i cant see this accounting for a sharp drop in power and noticeable slowing of reving. It was so sharp that on some of the runs the dyno would stop recording after 5500rpm as it thought peak power had been reached.
Also forgot to mention that the car would backfire once on some of the runs. Also the tuner said that the ignition timings we were running would usually cause pinging, but he was surprised that it was not.
Thanks for the replys so far :thumbsup:
Edit: My KW graph looked a lot like the torque graph above, but staying flat through the 6000-7000rpm range
Edited by Sparky206
had a similar problem myself. It was the stock rubber intake pipe distorting/sucking shut.
my symptoms led me to find this out as it was doing it more when the conditions were warmer (therefor rubber is softer and more able to be sucked n distorted).
I put in a metal intake pipe n that sorted it perfectly.
if you are only every going to go for about this power (famous last words) then one of the cheaper silicone intake pipes may suffice but otherwise i highly reccomend a metal one.
It also means more power is possible in the top end due to the better air flow.
I went from 290rwhp @14psi(when the intake wasnt sucking shut) to 300rwhp @14.5psi (the intake allowed for a bit more boost) just by replacing the intake.
Consistent with exhaust valve spring issues ???
Did you have a similar power curve to the torque curve above with an almost instant abrupt loss of power?
hey mate,
when my car was tuned it did the same sorta thing.......simple problem and wondering whether or not you have checked to see if your air filter plumbing is sucking closed. this would probably??? show up on tune graphs (a/r ratios etc).
we reinforced it and hey presto everything ok.
hope you can sort it out
Mick
If that is a final run with correct dyno settings on full throttle I would suggest to check the factory actuator adjustments or it’s in need of a better actuator or a leak from some where.
else it was very similar to mine when I discovered the valve issue, I could initially get away from that dip by patching up timing and till it stopped responding and the depth of the dip became random. The R33 Rb25det would generally give a small dip after 6800RPMs while Neo engines don't.
Did everyone miss where he said it backfires? Backfire sounds like it is missing, for it to miss it sounds almost certianly like an ignition issue, old shagged coilpacks almost always cause a miss around peak torque (4500-5500rpm). There are loads of threads about this issue, surely this has to be the problem?
Check the spark plug gap as well, 0.8 is the largest I would go. Toshi is in Japan, most japs tune the cars very rich around 10:1 from what I've seen, this exaggerates any weak spark problems massively making any misses due to poor spark even worse, you don't have to see cracks/etc for the coils to be stuffed, mine looked perfect and were stuffed, fixing the tune up from 10:1 to 12:1 completely removed the misfire in my situation as well.
The only other thing I would bet money on is the intake sucking shut, but I can't see how this would cause a misfire.
edit: You say you have an R33 ecu but these cannot be nistuned, the most likely option is an R32 ecu, however these can't control VCT, how is your VCT being controlled? If it isn't switching off at 5000rpm correctly and is keeping the exhaust cam retarded you will see a big dip in power over 5000rpm, make sure the VCT is switching on and off correctly at the right rpm, this could also be your issue, I can't see it would cause any backfires though.
edit2: just saw that it wasn't nistuned, ignore my first edit.
Edited by Rolls
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
