Hi guys i want to put a exhaust kit on my 2003 V. I was looking at a HKS kit but its prity pricy and just wanted to know if anyone knows of a better alternative to a HKS kit that is going to give me the same sweet sound that a HKS will, and also does anyone have any vids of the end result as i have only seen a few G5's on youtube.
for the budget conscious:
http://www.xforce.co...Nissan&model=34
Got quoted $1475 for the system (includes X pipe etc) from them. I think with the $US rate at the moment - people should dig into the overseas market. I saw a Borla true dual catback for $US1,100 a few weeks ago. Shipping was $US 300 - all up still works out cheaper than the X Force. Nonetheless, I've heard the X Force in action and it does sound good - also supports the local boys, which is always a good thing thumbsup.gif
exoticspeed r1-t pwr i had it on my v, beautiful sound, sold it to a sau memeber for his v msged me when he put it on and he also loves it. around 1.1-.1.2k mark i got it at (estimate ill have to check actual price) but i think its lower now since better aud to usd.
Does any one know any local exhausts for the sedan or and from Japan
I’m just pricing some up out of the states (stillan) and these prices are ok but I would rather go local and keep my money here
heard some clips on youtube with 350z having the megan exhaust systems. but can't really tell by just the free-revving sounds coz some exhaust sounds good revved but are sh!thouse driving normally coz they drone around the 1.5-2.5k rpm
I have the Tanabe Medalion Touring dual cat back exhaust system. Was on the car when I got the car. But it's great, no drone and under acceleration it sounds brilliant. Nice chrome tips too.
Have you looked at any of the japanese options, dont know if i'd trust HKS USA. The Kakimoto Cat back Twin Exhaust is around $1300-1400 shipped to aus. Most of the single systems are around the $900 mark shipped. I like the look of the GP Sports Exas Evo Tune twin cat back, but im still waiting on a price for that one.... could always get one of the amuse titanium exhausts if you want to spend like $5000 haha.
Gosh they are some high priced exhaust, I suppose they are quality, a replica HKS true dual headers back is not much more than 400 shipped from USA, pm me if you want a link. why you would want an exhaust confuses me but best of luck!
Edited by Texas G
street cred yo' :lol:
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
