hey
i recenctly bought a boost guage for my r33 gtst
went to install it today
i was goin to T into the line that runs from the black box (back left hand corner of the engine bay when standing at front of engine bay) this line runs to the back of the intake manifold.
after cutting this line i realise the T piece supplied was to big for the line.
question is whats the best way to go...replace the full line with a thicker line, or find a T piece that will fit this line
and where would i be able to buy a T piece or the new line
Thanks for your help in advance
heres some pics of the line ive tried to get into...
https://www.sau.com.au/forums/topic/362964-boost-guage-help/
huh? why would he tee into the bov line, when he has that line right there? it's ideal for running a boost gauge. just replace it with new hose, and T off it.
and you may as well leave the stock gauge connected. no point it sitting there, doing nothing.
Edited by Munkyb0y
LOL! Im not entirely sure why i put BOV in there :domokun:
Tis what happens when you try reply on multiple forums at the same time.
I guess each to their own. The stock gauge is idiotic. i like mine sitting at "0" all the time. Haha and if you have a new one, your hardly going to look at the stock one.
thanks for the replies guys
ill head over to the shops tommorow and sort something out
lesson learnt dont start work on the car late arvo if something goes wrong cant get spear parts till the next day.
i think ill T into the line...any sudgestions on where i can get a new T from?
thanks
Doesn't happen to be an Apexi Boost Gauge does it? They supply a 4mm T-Piece and the vac line to the black box is only 3mm. I went out and bought a 4mm vac line and ran it straight from the intake plenum to the gauge to the driver side firewall grommet.
Make sure you buy a vac line that has a small outside diameter or it will make life difficulty feeding it through the firewall.
nah its not an apexi boost guage...i got a gift card for supercheap for my birthday they dont sell much so thought id just get a boost guage of them, yes its a cheap calibre guage but they didnt have anything else i needed.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
