  • Replies 273
Just read the thread from start to finish.... Very inspiring story!! love the photography.
Same, took me all day..
Very nice car mate, You have a really interesting story to tell, and its great to hear that you can actually go out and enjoy your wonderful car instead of being hospitalised or stuck at home.
After reading through your trips through gorge road, I couldnt resist any longer, I did a full gorge road cruise today, finishing off my nearly perished clutch.
From there I went to the bay to have dinner when, And im not sure, but I spotted a really nice ceffy like yours down there today, Saturday the 19th of November 2011.
Good work with the car, what are future plans?
How'd the hard intake pipe turn out Rohan? Big difference in sound?
There is a quite significant difference, with a louder and more pronounced high-pitched intake and fluttering sounds. Still doesn't sound quite as good as Prach's and Daniel's cars, but they're both running 15+ psi.
Will include a short clip from the hills in the next post.
Thanks, yeah it is nice simply be able to drive! You certainly appreciate something more when you're not able to do it for a very long time, good to hear you got out there for a nice run too. That wouldn't have been me, but there aren't too many white Cefiros around.
Exterior wise I'm pretty happy with it, so going for a bit more power now. Picked up some 550cc injectors a few weeks ago, and will probably go with a Nistune/Z32/Neo turbo combo for maybe 180-190rwkw. Then planning to hit the track for some drift practices, motorkhana, and light general motorsport events if I'm well enough.
It had been a very long time since I'd shot a car using my Speedlight flashes. While they do make photos look way better in general, given that you have a lot of control over the lighting, it's also quite tiring running around setting up the camera, tripod, 3 flashes and sometimes 3 radio control flash trigger on light stands.
But since I was feeling able to, I charged up 12 AA batteries and headed out into the hills. It was hard to actually find a good spot. There are heaps of great locations, but they're all on roads that are used by other cars, and therefore unsuitable. After cruising around for a while, not following any particular direction, I came upon a slab of concrete near a big shed, with rows and rows of some sort of plants in the background. It wasn't perfect, but a safe place to stop for a while and set everything up.
I was quite out of practice using the flashes, so I did have to run back and forth adjusting the position and distance of them, while shooting from different angles.
After taking so many photos of my own car, I've figured out that Cefiros look sort of odd when using a wider lens closer to the car for some reason. Anything above 50mm is ok, but it probably looks best using the 85mm, which I used for these two photos below.
Here's a shot using just the natural light.
And one with the car lit by three flashes. You have to be very careful with reflections and hotspots from the flash units, but this lighting technique makes the details on the car pop a bit more, particularly the wheels.
This is the lighting setup for the photo above.
While I was shooting, a man came up on a quad to ask what I was doing. I explained I was just practicing taking flash photos, and asked if I was in his way, being in front of his shed. He said it was fine, and that the whole area was full of his apple trees. He was curious about my car as he didn't know what it was, so we chatted for a bit about cars and apples, before he had to get back to work and roared off again.
I was getting quite tired after going back and forth adjusting the position of the flashes, so I packed everything up, taking a shot of the rear quarter before I took off again.
Climbing up the slope visible in the background of the setup shot, there was quite a nice view of the rolling hillsides in the distance, with trees lining the narrow road.
Another guy working at the apple orchard stopped next to me on his own quad, and again chatted for a few minutes before moving on.
didn't really have a particular destination in mind for the day, so I just turned down whatever road I fancied, enjoying the improved induction and turbo noises with the new aluminium intake pipework.
While I had generally stuck to bitumen roads, the different scenery and grip on some of the gravel and dirt roads was tempting, so I turned down one that looked interesting to see how it would go.
With a dust cloud trailing behind, I had a bit of a random drive around for a while, the loose gravel surface and 1.5 way mechanical making corners more entertaining. Trundling past a few properties, I spied the cab of a dilapidated old Bedford just sitting by the side of the road. I couldn't pass up the opportunity for a few photos, particularly as I didn't really know where I was, and would have a lot of trouble finding the place again; I learned that the hard way.
While the Bedford cab was the only bit of machinery next to the road, the property itself was an automotive graveyard; with numerous cars, trucks and trailers sitting around in various states of disrepair.
This old Mercedes 1418 looked quite interesting, and I would have liked to get closer for some better photos, but with the fence and no people around to ask permission to go in, I stayed outside and got what I could.
Tired and with the Ceffy coated in dust, I called it a day and went back home.
A couple of weeks earlier, I'd noticed a funny looking turbo plush toy on the Sleeka Spares facebook page. I hadn't seen anything like it before, and got them to reserve one for when they came in to Australia.
After being told they had come in, I made my way over to their shop, stopping for a few photos near the wetlands on the Salisbury Highway connector.
It's a good bit of road to use for photos as it's fairly quiet, and no reason for the vast majority of people to head down there, aside from the odd birdwatcher you can see above. I've done quite well taking photos in exactly this spot, the main achievement being a Truckin' Life magazine cover photo and lead article that I both wrote and photographed...
...as well as a feature on this cool Ford XC ute in Extreme magazine.
Parking up at Sleeka Spares, there were a few interesting cars scattered around the street.
I made a beeline for this tough JZX90 Toyota Chaser after getting out of the car. I've seen a few of them used as drift cars, but it's very rare to see one on the street, particularly compared to the number of newer JZX100 Chasers kicking around.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
