  • Replies 273
With the wheel specs noted, we moved on to replacing the grille. After Prach spent a couple of minutes fiddling with a few screws and clips, the old grille came out quite easily.
It kind of looked like a hillbilly with no front teeth when I closed the bonnet to see what it looked like without anything there.
The new one was pretty easy to snap in place, and a few minutes later the Ceffy had a markedly altered front-end appearance.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6096824
There was a sedan sitting at the warehouse door with the front wheels on ramps, and a couple of guys working on it. I didn't have a good look at the time, but I think it's a Toyota JZX80 Cresta or Chaser, a model I don't recall having seen on the roads at all.
The style I'd most taken a liking to were these kind of mesh rims. There are so many variations of similar styles that I'm not 100% what these are, but I think they're Work Stitches.
I had a look at the specs; the rears were 17x10s, -23. A full inch wider than the P1s, and with a negative offset, they would be very hard pressed to not stick out the guards like a 4wd. But we rolled one outside to see how it looked next to the car anyway.
One the way through the warehouse, one of the guys working there asked what car it was for. I said a Cefiro, and he had a bit of a 'That ain't gonna fit..' expression when I said it. Which is a fair point, the 17x9 P1s are pretty much flush with the guards as it is.
They did look good when Daniel rolled it across the rear wheel arch.
There was no way they would fit without some serious guard rolling, but it was fun to have a look anyway.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6097888
After a bit of a poke around and with daylight fading, we started to head up towards Tea Tree Gully and into the foothills. After a fairly busy day physically, my stomach wasn't all that pleased with me doing more than usual, so I was feeling rather off for a while on the drive up.
Having syringed a couple of cups of water through my jejunostomy feeding tube before we left, the fluid had made its way south, and before we drove up into the hills, I stopped at a tavern for a few minutes.
With sunset fast approaching, I jumped back into the Ceffy, and let Daniel take off in front of me. His Pintara makes around 160kw at the wheels compared to my Cefiro's 139kw, so he does have the upper hand power wise. Although I'd already been on several hills runs at this point, both by myself and with my girlfriend Sally, being able to head out with a mate in another noisy turbocharged car was awesome.
So we wound around some of the twists and turns for quite some time, enjoying the power, the fresh air, and the sounds of spooling turbos and crackling exhausts against the trees and rocky hillsides. Driving in the hills was enough fun to take my mind off feeling sick; although this generally doesn't work if you're in the passenger seat. By the time we made it into the small town of Gumeracha, the sun had just set, which meant there wasn't much light left for photos.
So we both pulled into the carpark adjacent to the town's main oval, and I grabbed my Nikon D300 and Nikkor 50mm f/1.4, and started rattling off some shots while there was still enough available light left.
Without a tripod or enough time to use one anyway, I just pushed the ISO up on the camera, while opening up the 50mm to let as much dusk light in as possible. It was really quite cold by this point, fortunately I had a jacket in the back of my car to wear, but Daniel was only wearing a t-shirt and shorts, and didn't find standing outside in the chilly hills air particularly comfortable.
So here are some of the quick snaps I took of our cars.
After getting thoroughly frozen while standing outside taking photos of the cars, and the sky darkening too much for handheld photos, we headed back to Adelaide.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6097892
Yeah, spoiled for choice with that lot!
When I bought the Cefiro, I was under the impression that it already had a HICAS lock bar fitted. But while taking the rear wheel off, Daniel pointed out the fact I didn't actually have one. So the week after I made a trip to Sleeka Spares to pick up a lock bar kit.
http://www.sleekaspares.com.au/
One thing I like about visiting import/performance workshops, is that there are usually at least a couple of interesting cars around whenever you go. Walking across the road, I saw this late 1990s Toyota Corolla Levin coupe sitting in a yard opposite Sleeka Spares, a model that is very rare here.
There were a few carcasses walking through the gate, including this Toyota Celsior which had certainly seen better days.
I wasn't expecting it, but there were actually two Cefiros sitting in front of the shop, clearly both track only drift cars.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6099576
The pink and black Ceffy belongs to Kelly Wong, one of the shop owners. A very small minority being a female drifter, she takes it to the track for some sideways action quite often, here's a short clip from Mallala.
Once inside I had a bit of a look around at the parts and stuff, and then bought the lock bar kit.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6099584
The Cefiro was becoming a daily driver now, and I drove it around to places fairly regularly. Sally and I visited a couple of friends who run a hip-hop/breakdance studio, and while they practiced I mucked around a bit taking photos using the mirror and reflections in the window, which made for some interesting shots.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6099588
I got the itch for more hills driving after puttering around the suburbs, so on a decidedly grey afternoon I made my way up to Gorge Road, and proceeded to increase my fuel usage threefold.
It began raining fairly soon after I started to drive further east, which made the drive a bit different to the others. After the first section of Gorge Road it settled down a bit, and I pulled into a lookout area as the sun came streaming through the fast-moving clouds.
While I do like having my car nice and clean, there was a certain amount of satisfaction in seeing the Ceffy dirty and dripping wet, with the exhaust burbling away as I snapped some pics; it's made for enjoyable drives like this.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6100908
It started raining quite hard soon after I took off, to the point that I pulled up in a slow vehicle lane on Gorge Road for a few minutes, as I couldn't see too well. It died down fairly quickly, and I went up and back on one of my favourite sections. With a cliff wall right next to the road, you get some pretty epic exhaust sounds when you put the foot down.
Since the roads were still quite wet, I was taking it fairly easy. But at the end of a gentle corner, I hit what must have been a patch of oil at about 50, and the car immediately snapped sharply sideways with no warning. With a rock wall on one side and guardrail on the other, I had to pull over a few minutes down the road to change my underwear.
https://www.sau.com.au/forums/topic/363022-my-ceffy/page/6/#findComment-6100918
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
