Series 2 / 3 only, RB20DET only, Auto only.
Biggest giveaway is the front suspension, R32 GTS4.
Strut towers are closer to the centre (less room in engine bay than RWD Cefiro), Strut towers have 2 holes at the top, not 3.
They use an upper control arm, different knuckles, etc.
Next biggest giveaway is the driveshafts at the front and its ability to smoke tyres :P
Pull the ATTESA fuse for RWD
my coilovers here got 3 holes so rwd and stuff from s13 fits if i'm right :worship:
thx bro :thumbsup:
still thinking about buying your ceffy key but my wallet is in hurt :wacko:
btw another question, i got here in my ceffy some f**ked up leaking tein coilovers, if i buy some from a s13 the springs are too weak, could i just change the springs and all ok?
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 馃檪
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 馃 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 馃槉, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive 鉂わ笍 . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts 鉁岋笍
