Rb26 Engine Failure - Who's Fault?
Best kept secret for seized bolts is crayons... Heat the sucker up with a torch, and push/melt crayon into it. Works a wonder. See if I can go 2 from 2 for you on how to get your bolts out...
If you can get heat to it somehow that and penetrating oil will do wonders. Induction bolt heater, whatever it is. -
I frequently tell people interested in buying a GTR to either pick a 996 Turbo or E92 335i 6MT. Either one is close enough to being what you wanted from a GTR while being much, much cheaper. I just have brain damage and had to have one anyways. -
I really hope those injectors work for you. I have recently heard from another person with an RB20DET about how they cannot get their car to idle at all and they are tearing their hair out. I never really knew what the issue was but to me it had to be either the ECU or fuel injector. Suddenly on the wideband after sitting in closed loop idle for a bit it would lean out and stall.
