Hi, I'm up in Cairns also and the roads can be really rough. I've got D2 racing suspension on my R33 GTR, had Fulcrum try and soften them up, they said the front springs were under 800lb, what kg/mm ratio is that likely to be- I think they said Tein super streets are around 250lb- I know they're hard that's for sure. If I try and soften them much more I think I'll bounce off a bad corner- I drive up and down a mountain range each day, only way I can justify having such hard springs still :)
1 kg/mm = 54lbs/inch.
So an 800lb/in spring is near on 15kg/mm.
Which is an absurdly high spring rate.
Thanks for that. Bought it on the Gold Coast, seems the guy was building it up to be a bit of a monster, ridiculous clutch too (1300 kg brass button), not sure what he was planning on doing with it, but he wanted 500+hp, go it on 400hp now because he didn't do internals.
" I drive up and down a mountain range each day," lol, go the Kuranda hey
I would still like to do this, but been paying attention to the bumps more now since I been thinking about it, and man these roads really are pretty rough in alot of places. Need to stiffen it up though, have already scraped my new front mount a couple of times with the car pitching forward when going into some of the ridiculously angled driveways we have here.
Yeah, from Kuranda, haven't been driving lately because I had a shoulder reconstruction, my coilovers are going to shake the sh#t out of my shoulder when I'm allowed to drive; as djr81 mentioned my spring rates are a bit over the top. I had to have my R33 raised a bit to cope with the curbs, couldn't even get into many servos! now it can be a bit bouncy in corners with bumps, haven't noticed any problems on braking though. I just can't bring myself to replace a working product, I've gotten used to them now.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
