Thats not a very fair comment. Some people actually enjoy working on cars and helping people out. Not just out there to get rich.
U don't trust a person but u trust Ebay gaskets lol
haha
hmmm..i do see your point...the gasket was from nitto though. They sell good stuff, dont they?.
i didnt say dont do it, I said only do it if you trust the guy, Ive seen some horror stories of the guy at the pub that said he would do it on the cheap..mostly i was trying to convince him to do it himself cause he thought he could
Getting is out is not that hard, getting the water banjos back on is a royal PITA.
Without a doubt, that is the hardest part!
Took me at least an hour to get the first one back on!! Then about half an hour for the next, and the last 2 were easy.
ive got a 3" dump. but when you run a small highflow (21U) around the track for 3 months the manifold and exhaust housing on the turbz don't last.
Mine is leaking atm (near blowing the gasket to shit) and will only do 1-2 more track days before it all needs to come out again.
wow that bad huh , cant upgrade to an OP6.
So you just have to pull it out and replace housing and manifold or just gaskets?
You must be doin quite a few trackdays then, im pushing more power through the same housing but it doesnt get flogged anywhere near as hard as yours, well not consistently anyway :P be interesting to see how it lasts I guess my ebay gasket will no doubt give up before anything else , at least I hope it does
Trent fixed her up for me last week too,, come round and have a drive if you like sometime its running great. 430nm at 3500rpm See what ya think ;)
Really?
I thought (hoped) half way through ...
But anyhow, everybody has a first time at everything and I will get there (eventually)
you have all the easy but fiddly bits done. all you have left is the hard and fiddly bits with a side order of swearing to go. lol. don't worry, you'll get there
>_<
Yes, you are right .. now it is hard and fiddly.
(unsure which part of the work I like better)
I was meaning to remove the turbo yesterday, but had to buy 2 axle jacks first (poor excuse)
But I removed further piping and also prepared the turbo by undoing the locking clamps.
I remember when I first removed the cylinder head of my motorcycle, it took 4 hours.
After some practise I was able to remove it and put it back on in one hour :)
Cheers from London ..
Alright,
The Turbo is out ..
Worst bit:
The Water-Return-Pipe banjo bolt.
Also the turbo to manifold bolts gave me much less trouble than expected, thankfully I had an ultra slim ring-spanner
in my toolbox ... and it was even 17mm! :) The spanner did fit right over the nut, so I was lucky.
I did not remove the dump-pipe from the turbo, it was not a problem getting the turbo out.
(Just removed the 3 nuts from the downpipe to dump-pipe connection.)
Would I do this again?
Yes, but only in a proper garage ... not in an underground parking space.
More later ... many thanks for the help .. :)
Edited by Torques
nothing wrong within an underground carpark mate.
At least its out of the rain
This is my 'garage' and its been apart more than a few times before in it..
This is actually an upgrade my last 'garage' was only half as big :D
Good point, yes .. I plugged every opening with a cloth ..
Especially the pipes to the inter-cooler which are now wide open .. don't want any clip ending there, and then being vacuumed
by the turbo ...
Becareful with the compressor outlet of the turbo or any other opening eg cooler piping etc. Cover them up with rags or similar, its very easy to drop something in them.
Haha ....
Yes, nothing wrong with it, but I got strange looks from fellow citizens ;)
I like your garage ... very airy and no prying looks!
Also close to the next fridge I suppose!
BTW:
Attached why I had to remove the turbo ..
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
