Location - VIC
Phone - 0422 206 869
Price - $12,500
Up for sale is one of the cleanest street cars you will find. I barely get to drive the car anymore as I work in the city.
I have owned if for 7 years and was the first owner in Aus. It will be sad to see it go.
It is serviced religiously with Motul 300V Chrono every 5,000 kms also gets oil filer and spark plugs changed.
100k service with all necessary parts being replaced along with an Excedy heavy duty clutch when the engine swap was completed.
The car has had a full respray and an RB25 conversion including gearbox – just these alone is almost the asking price of the car!
It is a pleasure to drive and great on fuel – 400k’s+ per tank.
The car has been engineered and is currently registered till late 2011 so there won’t be any issues for the next owner – I can supply all documentation.
At this price the car is a steal.
Please no timewasters – sorry I am not looking for trades. Happy to answer any questions
Exterior
- Full respray in VW R32 Deep Pearl Blue (Inside & Out)
- GTR Front bar to suit GTSt
- Carbon GTR Grill
- 17 inch Driftek wheels
Handling
- Koni Shocks
- Apexi Springs
- Racebrakes RB74 pads
- Front & Rear Strut Braces
Interior
- GTR Drivers seat
- Apexi Boost Gauge
- Nismo Urethane Shifter
- Sound system 6x9’s etc
- Apexi Pen Turbo Timer
Engine
- RB25DET Conversion with RB25 Gearbox
- Apexi Power FC with Hand Controller
- Z32 Airflow Meter
- HKS 2530 Turbo
- Pod Filter
- Blitz Return Flow FMIC
- Blitz exhaust
- Yellow Jacket Coilpacks
- Hard silicone intake pipe
- Bosch 040 Fuel Pump
Other
I will also supply (uninstalled) for no extra charges
- Standard air box
- Standard ECU
- Standard AFM
- Standard intake pipe
- Standard Coilpacks
https://www.sau.com.au/forums/topic/363137-r32-gtst-with-rb25-conversion/
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
