As some of you might already know my engine has been a little sick for a while now, had a drinking problem and a bit of blow by - all the usual signs of a cracked ring land. Last weekends cruise was the last straw for it. After a thoroughly entertaining run with dan_the_man, it started smoked prefusley from under the bonnet and felt really under powered on boost. Cutting the cruise short, it was only when I got home did a rythmic 'clunking' make itself known. Took it by SST the next day and the diagnosis was a broken piston.
Whats next? After a few days considering all the options (cheap fix and sell, wrecker RB25, wrecker RB26, rebuild RB25), the final decision is a RB30DET build up, oh yeah! Pictures of the carnage forthcoming.
https://www.sau.com.au/forums/topic/36314-1-to-rb25det-rebuild-count/
  • Replies 45
Adam
Look here mate http://www.skylinesaustralia.com/forums/sh...ead.php?t=15420
lots of info on RB30DET. In fact, basically everything you want to know. There is also a link off that page which much more info too i'm pretty sure. I don't think it works out to be the most cost efficient thing to do however.....
Cheers!
Dave
Zanda, forged pistons and maybe rods (works out cheaper than shot peening).
Nexus_SiX, like an elephant, you are. That happened damn near 3 years ago now :D.
HIPSI, $6k minimum if you want forged pistons and other strong bits.
SeriesIIGTST, it's exactly $250 dollars (price of a RB30E) more than a standard forgies rebuild. So yes, very cost effecient. But I conceed its also not for everyone, especially those who want revs.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
