  • Replies 45
FIRE IN THE HOLE!!!! :microwave:
Did it actually blow though? or u just knew it would?
I think its basic knowledge that anything over 250rwhp on stock internals is a game of luck and is just a matter of time.
And here are the rods. The rods each weigh in at 688g +/- 1g. It'll be interesting to see how the weight of the stock rb30 rods, stock rb25 rods and these forged rods compare.
You can just make out the ARP bolts in one of the pics. Those are near $200 for 12 if bought individually, so a useful saving when the rods come packed with them ;).
Did I say RB30DET build? I meant VH45DETT...
Damn, still a few hours too early for April fools jokes, innit ;)
Its cause they're rods for a 350 Chev. They are 6" and also happen to fit RB30s with a small modification. I bought them new in the box from a fellow who was building a Chev engine and presumably changed his rebuild plans. Even though I'll only be using 6, they were at a price too good to pass up.
matlowth, I am told they will fit rb30 motors using 40thou bearing machined down to suit the rb30 crank.
From what my engine builder tells me, only certain Chev rods are suited for this appiication. The big end is too wide (>86mm) to fit in the RB30's bore, so small amount of meat has to be machined away from around the rod bolts. On some rods this wouldn't leave enough metal for the bolts to hook into, on others its fine.
These rods are made from 4340 steel, magnafluxed, sonic tested, x-rayed, heat treated, stress relieved, have bronze bushings and were $500 for the set. Compared to $800 to shot peen and ARP rob bolt my factory rods, I thought these new rods were a slightly better deal.
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
