the turbos sounds good to me. Im not an expert or anything but I would be sure to ask them about the results of the turbo on a rb20. Maybe the can send u dyno sheets, and even pics of the cars.
as long as i have been researching I seen the hks 2530,2535 or a lil laggier 2540 and 2835 are most suitable for skylines.
Im hoping to get a 2835 in the future.
:cheers:
let me know how you go
take it easy
My thoughts are you could most likely do better. I have a Trust turbo so this applies to me as well, but the turbo isnt water cooled- so run an oil cooler, and isnt ball bearing-but it does have 360deg thrustplate.
And going on those specs i dont think it will make 500hp, how much hp are you chasing?
Did you read Roy's post?
hi i am not looking for major performance say like 300-350 hp,i ahve an apexi exhaust(due to be changed for a hks single box exhaust)a hks air filter and bov,and a mines ecu..the turbo is standard and can only seem to boost to 0.5,i have put a bleed valve on aswell to see if i can get to go higher on the boost,but seems the more you open it the same it stays...and i have checked and double checked everything so i have jsu put it down to a dudd turbo....
I doubt that it's a dud turbo ... more like a dud bleed valve. Or you have put the bleed valve in the wrong way round. If the turbo was dud it probably wouldn't make any boost at all :D
That turbo you put a link to should be able to make what you're looking for on an RB20
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
