Decided with the exchange rate I'd import a accusump kit and 'T' it into my oil cooler install. I'm unsure which size one to get as yet (bigger the better) but that will come down to the restriction(s) of the mounting location.
I need ideas for mounting locations.
mine is installed in the boot.. [distance of 3.2m of -10 braid] i emailed Canton and they said this is fine, so long as the pressure actuator/valve is still installed in the normal position on the outlet of the accusump.
the braid is secured under the car - the problem i saw with mounting in the cabin is the fact you have hot oil sitting there in a pressurised state (also the reason why i didn't want it mounted in my front bar)
after a couple of cycles there will be no air in the system
Chris
EDIT:
i also went with the Moroso check valve (so oil goes straight through your engine, and isn't pumped back through the oil cooler) and the Moroso accumulator mounts
http://www.moroso.com/catalog/categorydisplay.asp?catcode=13600
Got these from Performance wholesale in QLD for about $80 for both, they can post as they order from their Sydney warehouse anyway
Edited by kristafa
Above coilpacks or behind front bar reo. Although the latter will get you in the shit if you have a front on.
Other options are in boot, pasenger front quarter (although this means you won't be able to manually activate the valve so you should buy the electronic solenoid for it. You should also buy the 2quart one, not the 3, the 3 is about 50-55cm long I think
Battery relocation is a great idea actually, since it's a R32 it's still in my factory position (the drivers side front corner). I'd like to keep the accusump as close to the enginebay as possible as my oil system (cooler, lines etc) already requires ~7litres
As for boot mounting the accusump, is it difficult when doing a complete oil change to do the oil inside the accusump and the line going to the boot?
Just let the accusump discharge fully (pre lube) into the sump with sump plug out.., all that will be left in the line is a few hundred ml's.. Disconnect and blow into it if you want that last bit out.
  • 2 months later...
They're just a light weight hydralic accumulator...
They work quite well if set up correctly. There are a few cars that rely on them to get around our local tracks without loosing oil pressure at a couple of particular corners.
You can use them as pre-ooilers as well.
Good things- I have two for my next project build.
J.
yeah you use them to pre-oil on start up, and then they can be set-up with a pressure switch. if through high g-cornering/braking/accelerating oil pressure drops it discharges into the engine to keep oil flow and pressure up. once pressure is above a certain point it recharges again.
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
