Mechanic In Hawthorn
5ully
 Share
hey all
ive just moved to hawthorn and im looking for a good mechanic to servos my r34 25gt, it is playing up a tiny bit for me when i dont give it alot of reves, is shutters a little please help
oh and ive seen a beautiful blue R34 in camberwell tonight that i think has a gtr front bar that i want to figure out because it is what im looking for my baby. if anyone nos the person or the body kit please let me no and if you have seen me driving around dont hesate to honk or wave im always up for a hello
mines a white R34 25gt 4 door
Racepace prob wouldn't be too hard to get to from Hawthorn i would think, prob good freeway access that way.
Is the car standard or has there been any modifications?
If you want a decent shop that won’t charge a bomb just for a service and isn’t far aware:
Intermarque
17 Islington St, COLLINGWOOD, VIC, 3066
9428 4460
They usually work on Euro’s with anything from old Mercs/Jag’s to new Ferrari/Porka's and so on. And the owner is involved with a lot of circuit racing in Aus/Europe :)
Taken my GTR and GTS-R there and been very happy with the work/price. There are a few other SAU members that take GTR's there as well that i won't name :thumbsup:
Helps they are close as I don’t always have a chance to get out to Racepace these days for the small stuff.
Guilty :S
well lol that was me trying to take a photo of your car as you went past only because its sexy and i want for front bar on my sexy beast!! oh have you seen me driving around at all
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
