I think I have decided on the Garrett GT2860R-5 turbos for my RB26 rebuild, but am just not sure if I should go with the "S/DiscoPotato" Version. From my very limited comprehensions of turbos, all the stats look the same except for the compressor and turbine maps which I do not understand.. Does anyone have any experience between the two? They cost the same so would going with the "S" version be a no brainer? There is also a 0.86 A/R housing option for both turbos, how would this affect performance?
Links to each turbo:
GT2860R-5
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT28/GT2860R_707160_5.htm
GT2860RS-5
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT28/GT2860RS_739548_5.htm
Thanks,
Carthik
AFAIK they are the same turbo, your right on the specs aspect of it.
The differences, as mentioned, are the housings.
The disco is made for a generic application which uses hoses and clamps for its intake side, where as the -5s will literally BOLT IN to factory position on the GTR. You can litterally bolt them onto a stock car without changing a single bolt else.
Do the research first and make sure the -5s are the turbo for you, but do not go for the "disco" version as that will cost you an all out arm and a leg to get onto the car for almost zero gain.
^^ What he said, although, I have NEVER seen a 'bolt on' -7/-5/-9/-10 turbo. Yes they bolt on with minimal effort but you still have to stuff around for ages modifying the oil drain as it fouls on the comp cover bolt etc. Other than that, direct fit
Also think the disco has a larger comp cover and turbine housing so it definitely will not fit without custom manifolds
Has a T04B comp cover and 'silvia' based turbine housing, so definitely need custom everything yea.
The direct bolt on thing is not without some stuffing around yeah.. But agreed all original items will bolt back on in the end with a little 'love'.
Has anyone actually tried the 0.86 housing option, just out of curiosity ?
Check this out....
http://www.skylinesaustralia.com/forums/topic/357831-garrett-9/page__p__5720166__fromsearch__1#entry5720166
I still want to know if there really is a "S" version to the -9 tho as my supplier quoted me....
Quick response, good power plus a lil sugar on top now???.......:thumbsup:
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
