I have just bought a 2nd hand ARC SMIC of off ebay for my R34 GTT. Before installing it I have have my mate who works at an intercooler manufacturer to check it out for me. He has set it up for a pressure test and it is leaking out all the bolt holes. I have tlked to the guy who sold it to me and he keeps trying to convince me that this is how it was produced. I find it extremenly hard to believe that a reputable company like arc would manufacture an intercooler which has bolt holes going into the tank and requires you to seal up bolts when you install.
IIf anyone has had any experience with these coolers or ARC and can shed some light on this for me it would be much appreciated.
on my phone so hard to see pics... but looks like its not bolt holes, and leaking from the core/end tank area?
If so... its probably been dropped or something.
It's possible it came like that and owner never knew as its not leaking heaps by the look of it.
It is definitely the bolt holes you can see they have been drilled through or retapped through into the tank when you look in the inlet and outlet.
The guy who sold it to me keeps harping on about making sure I seal the bolts correctly when I install it. Question is was the ARC SMIC manufactured with the bolt holes drilled through into the tank? I doubt that any intercooler manufacture would design an intercooler this way.
I work in a place that makes massive radiators and also repairs/services them and intercoolers. When we test them if there are any leaks we get them welded up. Then we test them again etc. Sounds like they stuffed up yours mate and I would send it back and get one that doesn't leak. P.s. I just bought a 600x300x100 (core size) intercooler from ebay. Only $240 to the door and doesn't even get hot :D. No leaks either :no:
What pressure drop though? :)
Problem is, I was sold an item that was supposedly it great condition and it is obviously not.
The intercooler manufacturer where I have had it tested does not recommend using sealant in the bolt holes due to the possibility that it will come off inside the cooler and enter the engine.
He has recommended drilling out the existing threads and welding in a new section of round bar which can be tapped properly.
To me this sounds like the best and most professional way to rectify the problem.
Back to my original question, There is no way an intercooler manufacturer would intentionally drill there mounting points through into the tank? I gather this is a correct statement.
Of course they are saying that...it makes them money.
Lol at sealent not working...wtf do you think is stopping air leaks in your turbo compressor housing where it bolts to the CHRA.
They are not making any money. They are going to fix pro bono as I know the supervisor there.
And they never said that sealant wouldn't work. Sealant can fix a multitude of problems.
But my question still remains unanswered.
Would ARC make an intercooler that requires you to seal the bolt holes as they are drilled through into the tank?
Mate the easy way out is to put thread sealant (white crap) on the bolts and fit it up. We use the same crap at work for fitting plugs into big steel and copper intercoolers (called aftercoolers but whatever) and they are good to 50 psi. Sounds like someone put bolts into your cooler that were too long and wrecked it. Get it fixed if its free but other than that don't stress :thumbsup:
2 psi less pressure drop than the r34 smic that was on there. I got 2 psi more on the gauge after I fitted it. A mate has the same one on his 45 psi 600hp plus sr20 drag car :thumbsup:
but to answer your question entirely, I haven't measured it
The bolt threads are also stuffed so like Room42 suggested I reckon that the previous owner has used bolts which are too long and has overtightened and stuffed them up.
As the going says don't treat the symptoms fix the cause.
I'll be getting the unit repaired professionally with new bolt stubs installed.
Didn't really get an answer to whether or not intercoolers are manufactured with bolt holes through into the tanks or not but thanks for your help anyway.
at the risk of trying to answer the original question.....I do not know for sure, but I cannot imagine any circumstance where a professional manufacturer would drill open holes through a sealed part of the intake.
sounds much more like dodgy prior installation than original build
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
