Garrett -7 turbos x2 low kms excellent condition come with acuators reday to bolt on
$1800
Sparco sprint V seats in black x2 as new condition with jdm rails suit R32,33,34 gtst and gtr will fit silvias and 180s also (will trade with s2 seats gtr seats or recaros and cash)
$1500 pair
Rb26 R33 gtr 444cc injectors under 20,000kms use
$250u
Rb26 RWD modifyed sump
$250
Trust copy Rb26 intake setup hot side piping silicone joiners pod filters and turbo ss intakes used
$200
Apexi power intake filters and afm adapters for Rb26
$250
Rb26 stock afm x2 32 gtr
$100
Rb26 stock cast exhaust manifolds x2
$100
Rb26 r32 gtr stock dump pipes x2
$50
Rb26 oil and water feeds for stock turbos
$100 for both setups
R33 gtr stock turbos rebuilt under 20k use on 12 psi x2
$500
Haltech e8 ecu and patch loom suit s14 etc
$1000
Hks series 1 cam gears x2 suit rb motors
$120 pair
Rb 26 r33 gtr stock valve springs and retainers under 20k use
$200
Rb26 r33 gtr stock intercooler good condition
$200
pm post or call 0422646961
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
