It's funny that the only cars mentioned to have cracked rear frames didn't have tow bars
Your comment makes no sence as the bars are only rated for 70kg or so down on the ball, and the pulling force is not directly linked to the sub frame.
If the trailer trailer/ tow ball height combination is level and the trailer is loaded wIth it's weight over the axel then there will be no issues.
Go nuts then. Doesn't mean I'm going to do it with my car. Yes, I know how tow balls are rated.
Look, I'm not trying to be a prick. I just don't think its an awesome idea on a car that wasn't designed for it. We know the subframe cracks, we know overloading causes it.
If you plan to tow big and long, please make sure you have an external tranny cooler, and you have seen to the turbo banjo, and the turbo is in tip top condition. I know another Stagea (C34) drivers been through 3 china turbos, probably because he tows a car with it! Maybe even get a radiator upgrade.
That's not entirely true, but it's not my place to identify the cars. Also, it seems more prevalent in vehicles with HICAS for some reason.
I have a tow bar on mine (the Fast Fit towbar was designed on my car); and frankly, I believe they just aren't suited to towing something the weight of a car. I put a tonne in my trailer over relatively short distances (100km max), but I wouldn't want to do any more than that. I only end up with around 30-40kg on the ball in my "worst case scenario". I haven't had any cracking issues.
There is no real chassis structure in the rear of the car that is suited to the forces you'll be putting through the rear sheetmetal.
All you are really using is the rear bar reo mounts; and this is a structure designed for compressive forces(think rear impact), not to be held in tension. The legs that go under the car are only there to stop you applying torsion (leverage) to the reo mounts; not to carry any great load.
As Alex said; go for your life if that's what you want to do, but just be aware. There are many other cars better suited to towing heavy loads; and have 2000+kg rated factory Hayman Reese towbars.
Edited by Daleo
  • 3 months later...
Hi all, was searching about sub frame cracking, as my stagea ARX has it on both sides of the upper subframe. I was wondering if there was any evidence for what the cause was - I baby mine pretty well and dont dump it off the line... BUT i moved house earlier in the year and loaded heaps of gear in it - AMAZING HOW MUCH YOU CAN FIT!!! So ..... That could be the main reason ... damn. Well it sat pretty low a few times... I had to move a 3 car garage...
Now.. can someone tell me how difficult it was to remove and repair. I imagine a good TIG welder could fix it pretty easy. Has someone done it ? did you re-enforce it with a peice of al over the top of the crack? thanks
  • 1 year later...
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
