It's funny that the only cars mentioned to have cracked rear frames didn't have tow bars
Your comment makes no sence as the bars are only rated for 70kg or so down on the ball, and the pulling force is not directly linked to the sub frame.
If the trailer trailer/ tow ball height combination is level and the trailer is loaded wIth it's weight over the axel then there will be no issues.
Go nuts then. Doesn't mean I'm going to do it with my car. Yes, I know how tow balls are rated.
Look, I'm not trying to be a prick. I just don't think its an awesome idea on a car that wasn't designed for it. We know the subframe cracks, we know overloading causes it.
If you plan to tow big and long, please make sure you have an external tranny cooler, and you have seen to the turbo banjo, and the turbo is in tip top condition. I know another Stagea (C34) drivers been through 3 china turbos, probably because he tows a car with it! Maybe even get a radiator upgrade.
That's not entirely true, but it's not my place to identify the cars. Also, it seems more prevalent in vehicles with HICAS for some reason.
I have a tow bar on mine (the Fast Fit towbar was designed on my car); and frankly, I believe they just aren't suited to towing something the weight of a car. I put a tonne in my trailer over relatively short distances (100km max), but I wouldn't want to do any more than that. I only end up with around 30-40kg on the ball in my "worst case scenario". I haven't had any cracking issues.
There is no real chassis structure in the rear of the car that is suited to the forces you'll be putting through the rear sheetmetal.
All you are really using is the rear bar reo mounts; and this is a structure designed for compressive forces(think rear impact), not to be held in tension. The legs that go under the car are only there to stop you applying torsion (leverage) to the reo mounts; not to carry any great load.
As Alex said; go for your life if that's what you want to do, but just be aware. There are many other cars better suited to towing heavy loads; and have 2000+kg rated factory Hayman Reese towbars.
Edited by Daleo
  • 3 months later...
Hi all, was searching about sub frame cracking, as my stagea ARX has it on both sides of the upper subframe. I was wondering if there was any evidence for what the cause was - I baby mine pretty well and dont dump it off the line... BUT i moved house earlier in the year and loaded heaps of gear in it - AMAZING HOW MUCH YOU CAN FIT!!! So ..... That could be the main reason ... damn. Well it sat pretty low a few times... I had to move a 3 car garage...
Now.. can someone tell me how difficult it was to remove and repair. I imagine a good TIG welder could fix it pretty easy. Has someone done it ? did you re-enforce it with a peice of al over the top of the crack? thanks
  • 1 year later...
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
