Hey guys heres my build plan would this be adequate just for using as a street car:
RIPS RB30 Stock internal bottom ends, with RIPS modifications, fully refreshed
Standard R33 RB25DET VCT head *is there any modifications needed or just bolt on?*
R33 GTST PFC with boost controller kit
Yellow Jacket ignition coils
Walbro 255l Fuel pump
GTR intake plenum with 700cc injectors
HKS 3037 Pro S turbo *should i go bigger to a GT35R?*
Items in consideration:
Nitto Oil pump
Enlarged Sump
Cheers
Chi
https://www.sau.com.au/forums/topic/363243-rb30-build/
Sounds 'adequate' to me for a street car haha.
There is heaps of info in the stickies above on what mods are required to get the twin cam head onto the rb30 bottom end.
Only comment I will make is that if you choose the 3037 then make sure you get the larger 0.87 housing if possible. I would recommend either a kando T67 or a 3076 with 0.82 housing. For a street car I would leave the GT35R alone.
You might as well go larger injectors to give yourself more headroom and if you ever decide to run E85. I would go ID1000's. Not sure whether that fuel pump will be enough.
Will you be using standard exhaust manifolds?
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796770
The head bolts on but you can weld up/ block the VVT oil feed and shape the water gallery next to it and shape it to suit the rb30 water jacket. If you dont then there is approx 1mm of sealing area around that water jacket.
Go the 35R, the difference in price is nothing for the extra increase in power, you will be wanting more when u max out the 3037
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796955
the 26 plenum i have a blitz adaptor plate kit for it to be bolted on mmmm I think the RIPS 30 block has all the modifications so the head is to be bolted on without having to block the VCT oil feed etc ill email RIPS about this, exhaust manifold wise if i get a GT35R i will be going a 6boost manifold. but is the nitto oil pump needed?
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5796982
iirc it has an external feed set up. theres no way of doing it without blocking the original feed, as it overlaps with a water gallery on the 30 block. the other way thats on here is to feed vct oil from the cam buckets by drilling out a brass fitting in the head
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797002
I disagree, there is car on here (Al's) with an RB2530, he runs a GT3076 0.82 and makes 330rwkw with unbelievable response.
My argument is that I would prefer a super responsive ~330rwkw setup then a less responsive ~370rwkw setup for the street. It depends on the driver too on what they prefer.
I have just changed from a 280rwkw setup on an RB25 with less reponse and changed to 250rwkw with amazing response and it would beat the previous setup in all times but a rolling start from 80+ km/h
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797416
At 378rwkw I have no lag with a GT35R .82
Edited by Alf
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797916
Wow you just created the first turbocharged vehicle to not have lag!!!
I think you mean the lag you have is acceptable for you. Put the car in 5th gear at 60km/h and tell me you have no lag.
Im almost there with that feat! :D
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5797985
lol. ahhh it would appear I did...:whistling:
But to get back on point, the most responsive our race car ever was, was when it had a gt30 on it. Exact build spec was standard head and valves with tomei stage 1 cams retaining the vct, 6boost manifold with gt30 with .82 rear, 8.2:1CR and we were making 320rwkws. Then when we put a water methanol setup on it it bumped upto about 360rwkws and it was amazing! Pulled like a steam train but used to die off abit early up high.
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5799441
Exactly, what speed did it die off up high? I am tipping way above legal road speeds. Why such low compression??
https://www.sau.com.au/forums/topic/363243-rb30-build/#findComment-5800060
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
