Ummmmm Derrrrrrr ummm ............................... you ever think of sending him an email or PM, as I'm sure he would pass on all the info after he sees the message.
When I was looking at an RB30DET >>>>> MR30Ti sedatch, my research found it was reasonably easy.
Having said that, WHY! does he want to in the first place, because you of all people know the deal with L series 6's.
D
https://www.sau.com.au/forums/topic/363249-rb30e-in-r30/#findComment-5798655
this is your lucky day..
motor does drop straight in but sump does not clear mr30 crossmember enough for engineers.
you can either modify the sump for clearance or, do what i did and modify the engine mounts.
my motor sits about 10mm more forward than normal for the sump to clear.
If you arent bothering with engineers then just drop it in. I also did experiment with vl mounts and r31 mounts.
For memory one of them just dont fit nice at all but i cant remember which ones i ended up with. Might even be a mixture of the two.
Next is gearbox. I went with the mx7 out of the vl turbo. its big and long but fits.
Again the mount is not standard, just make one up or modify the r30 one.
The rest is pretty easy. Radiator is stock too.
I sent my loom and computer off to castlemain auto elecs who make up universal looms which are very easy to install.
I think that covers it. Makes a big difference if you go engineers or not coz you gotta meet all the adrs.
Cheers!
https://www.sau.com.au/forums/topic/363249-rb30e-in-r30/#findComment-5802877
in Qld an rb30et in r30 would be a breeze to mod plate. i know 2 guys with 120y's 1 with rb20det and other vg33e both plated and fully legal and they well under 1000kgs, mate used to have a 400hp rb25 in an ae86 mod plated. Qld is alot easier i hear but...
L series motors are good but id rather an rb anyday
jon.
https://www.sau.com.au/forums/topic/363249-rb30e-in-r30/#findComment-5809382
jon.
https://www.sau.com.au/forums/topic/363249-rb30e-in-r30/#findComment-5809383
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
