Hey hows it going a i got R33 Series 2 Manual Skyline and tonight i replaced a fuse that blew that controlled my interior lights. When i installed it i drove home and when i took the key out of the ignation the turbo timer didnt kick in so i tried shutting it off and the car wouldn't shut off. Only way i can shut off my car is if i take out my main fuse or stall it. Now i have checked all the fuses and none of them seem to be blown. However im not 100% sure on how do you check the fuses in the boot if they are blown or not.
However there's another problem is that the dash lights wont turn off even when the ignition key is out and turned off. Only way i turn them off is disconnecting the battery.
So if theres anyone out there that could shed some light on this problem and help me out, i will gratefully thankful for you help.
Yours Truly,
Nick
https://www.sau.com.au/forums/topic/363264-car-wont-turn-off-fuse-problem/
The fuse blew for a reason, there might be a short circuit in the wiring somewhere. Take out the interior light fuse as u suspect this is the last one u replaced before the issue.
Do u have an alarm tha starts the car? Can u completely remove the turbo timer incase the short is inside it causing the ignition to stay on.
Ive removed the engine control fuse and now the car seems to be working fine it turns off like its supposed to. I forgot to mention i also filled in the missing spot for it last night so i guess that was the cause of the problem. But i just want to make sure is it bad if the engine control fuse section doesnt have a fuse in it because im not sure really what it does.
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
    • The prices of NCs are going to go up thanks to you... and partially the MCM guys.
