  • Replies 105
While we are on the subject, I was after some info. My uncle owns light plane and CASA has informed me that I can't add this to the engine due to a couple of things, 1. It's not an approved addative nor a patented product and the chemical composition is not up to aeronautical standards yada yada yada?!?!? and 2. It reduces metal integrity by imbedding it’s self into the metal which on constant revving engines can cause a decrease in thermal efficiency. Sounds a bit ‘how ya going’ to me, didn't really get a straight answer from them, but do you know if any of this is correct? Thanks :)
An internal combustion engine is a great big oversize heat pump... it relies on heat not escaping in order to be most effecient. I'm also aware that Roil isn't for use in the general aviation industry... having been a pilot for the last 4 years, and studied aircraft systems at Griffith University (I'll quote you my CASA ARN and Licence Number and that of my licencing delagate if anyone thinks I'm BSing!) And i don't beleive Roil afffects 'metal integrity' when the pinion drive that powered the 2000 Australian national drag Champion 'Sainty' that ussually has be be replaced after every second run, and even then comes out with hairline cracks, once a new pinion drive had been socked in Roil for 24hrs at last count I beleive has done its 26th run???
Note the rather large Roil sticker infront of the right wheel!
HoeTrain, the reason CASA wouldn’t recommend it is because they are a bunch of spineless, ball'les beurocrats who will not accept responsibility for anything. They wouldn’t even tell you the time without receiving written conformation from another source (just incase they were wrong). In all honest CASA know next to nothing about mechanicals (or aviation for that matter) and are just a lot of mindless beurocrats that hide under the comment "its in the interest of safety" (translation = "I don’t know and am not prepared to make a decision")
Sorry a bit of a rant, but when you have been involved in aviation (both flying and maintenance) a our family have, you have little respect for these pencil pushing dickless morons.
id like to see a proper test done by the manufacturers... like BMW and Mobil did with an old e30 with mobil 1 in it. they put it on rollers for 1million km's (might of been miles, i cant remember) and ran the engine non stop, and varied the speed periodically. they didnt change the oil at all and when theyd finished there was very little damage to the engine (similar to an engine thatd run 100,000ks using basic oil).
if a test like this was done (a before and after) there would be no variences like driving styles. and no one could argue that your full of shit (im not saying you are)
they wouldn't have to do a 1million km test of course.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
