So yeah bringing back my drift car from the last Japan trip.
Drove this puppy 2000kms from Osaka to Ebisu and back.. Was rather good fun :lol:
Ready to drift, jump in and go. nuff said. never missed a beat at all.
Coilpacks all re sealed in japan, new plugs, oil were all done as soon as we got there. fault finding before drifting came up with nothing. Its a toyota, faults dont happen.
Specs:
Toyota JZX90 Chaser
~90,000kms
30mm front guards (drivers needs slight repair as it has a crack,
negligible if your a real man)
Full lip kit (unsure of brand, but looks tough. Front lip needs a bit
of love, or replacement)
Front pipe back exhaust (cat pipe and cat back)
HKS Triple Plate clutch
Labyrinth 2pd super lock Knuckles (spinning this car is NOT easy, awesome knuckles)
KTS tie rods
Kazama castor rods (110 conversion)
Solid rear cradle bushes
TRD 2 way LSD
Buddy Club Coilovers
FMIC
Koyo big ass Radiator
Greddy radiator return
Blitz SBCid Boost Controller
Blitz Rvit monitor system
Fuel pump is done
Defi Boost gauge with defi controller
Recaro passenger seat
Bride Ergo Driver seat
Nardi steering wheel
Rolls on 17x9 +11 front and 17x9 +17 rear vip dishies as shown in pics
ALSO comes with a set of 4 origin dna02 wheels 17x9 +30 white (seen in pic on the right)
dildo shift knob
Comes with stock front arms
other bits on it i cant remember. Basically its rather awesome.
Race Rally import (if someone is thinking of getting creative, i dont wanna know about it :lol:)
Located in Adelaide
$9000
(7.5k without the origins, rolling on R33 stockies, recaro drivers seat, stock passenger seat)
Contact me on
0405108194
or [email protected]
Catch
Pics Here
http://www.nissansilvia.com/forums/index.php?showtopic=487033
https://www.sau.com.au/forums/topic/363295-jzx90-chaser-drift-car/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
