MORE SOUTH CIRCUIT ACTION - VIEW ON THE BLOG
The ARDC announced a week prior to the last South circuit event, that the competition was cancelled and will resume to be a practice day. Our original plan was to go to the Wakefield Matsuri which is coming up in a few days, but we figured we’d hit up SC once again.
Kinetic Imagery was out and about again and managed to get a Vid of Benny and I in tandem, its bloody crazy how small his R33 looks next to the Stagea.
Eiji from Team Redstage made the trek from the ACT to check out the South circuit, he got plenty of coverage of the Stagea too.
Benny was killing it, laying down solid runs consistently. Starting to get ballsy on the first corner too … he managed to tap the barrier with his rear bumper, which resulted in it flying away haha.
I wish I could say the same thing about myself. I was pretty sketchy most of the day and finally started getting some good runs down towards the end of the event. I need to work on my entry to the first corner a lot more too.
It took me a while, but I managed to convince Julie to bring the S14 out and try the South circuit. She was a little bummed that we are no longer going to Wakefield, but luckily she enjoyed herself and considering it’s her first time out, she destroyed it!
I would have thought the Stagea would behave and let me just focus on drifting, but it wasn’t ment to be. In the morning it started popping out the dip stick, something it’s never done before.
Puzzled to say the least, I gave Anth a call and he told me to vent the catch can. After I did this all was well until I had a glimpse of the oil pressure gauge coming up to the first corner.
It was dropping from 80PSI down to 20-30PSI on full boost. I babied it for a few laps just to see exactly what was going down. It was dropping consistently and only near full boost. So I kept going and hoped for the best.
The Stagea survived the day and is running like a champ. When I got home I had a look at my previous videos from the South circuit and it was dropping pressure too.
It seems some GTR owners have had the same problem, and their remedy was to over fill the oil by roughly 1 litre. I used to do this but I think I stopped after the oil cooler install. Hopefully that’ll fix it.
I’d love to get my R33 front suspension together before the next day, or even just a wheel alignment and straight tie rods. I’ve been driving with bent rods for 3 maybe 4 events now. I’ve finally figured out why they bend too, which I shall touch on soon.
Thanks to the photographers for the coverage!
Rocking roof racks - view on the blog
I’ve had a few Stagea owners ask me about my Thule roof racks, and although I’ve been meaning to do a post about them it’s always slipped my mind when its crunch time. I originally bought these for the Raleigh Raceway matsuri trip late last year. As I needed some way of carrying my spare wheels/tyres up.
I didn’t go to that event in my Stagea, but we chucked them on Benny’s series 2 and definitely came in handy. Anyway my main reason for these was to be able to carry tyres on the roof, and other stuff if I needed to. Benny and I headed down to a place called Roof Rack World in Artarmon. They measured everything up and fitted the Thule gear onto the Stagea. It was all in stock except the fairing, but they went to their supplier and nabbed one. Service was excellent so I’d defiantly check them out if you’re in the market for some.
So now for what everyone has been waiting for … the part numbers!
•Front spoiler (Fairing) LC871XT
•Rail mount foot pack RT757
•Aero bar pack 120cm GL861
If I recall, I am pretty sure the footpack and bar lengths are similar if not the same to the Toyota RAV4.
There they are finally, sorry for holding out for so long. I had to go through all my paper work and find the part numbers haha.
THE QUEST FOR MORE - PART II - VIEW ON THE BLOG
I’m back tracking a bit here but here goes. My modified arms had returned from JDI Fabrication in Melbourne. I was eager as hell to see how they turned out, so as soon as they arrived I dropped everything to open the boxes up. Everything just ozzed quality, the cuts, the welds … I’m super happy with the outcome.
Lets have a look at everything shall we?
First up is JDI’s R33 Skyline knuckle, which happens to be the same that Benny is now running. With most cut and shuts the tie rod point is cut down, and shortened at a slightly different position. This is generally to reduce Ackerman. This means more lock, with less turns of the steering wheel, and the trailering wheel to be similar with the leading wheel.
The knuckles have been braced to ensure strength too.
The bearing carrier on the link arm was raised 30mm, and heavily braced as per my request. These measurements have worked out perfect.
The LCA is a nice piece of work. With a metric threaded rose joint, capable of extending up to 40mm. The boxed underside for strength, and the bump stop was removed for more lock gain. Jamie also made me LCA adaptor mounts to suit free of charge. Talk about service!
With the Stagea half apart, I did a rough mock-up to see if my theory’s would be successful. As is they could be a good option if my car was higher, but right now more work is needed.
The LCA makes contact with the chassis for a start. I now see why the GTR LCA has many bends and is designed the way it is … Nissan didn’t allow for much clearance with the 4WD subframe.
One of two solutions is to cut down the kink from the LCA so it is flat with the rest of the design. This would allow roughly 15-20mm more clearance. Another way to add more clearance would be to mount the rose joint on a slight angle.
The second solution was converting the LCA ball joint, to a rose joint setup with an added spacer to push the LCA down to a more acceptable angle.
The castor rod lines up to the R33 LCA, but needs to be extended roughly 40mm.
Finally the subframe doesn’t offer much room for the rack end. I’ve now figured out why I keep bending them! So I’ll probably end up cutting/bracing a section for the rack end to clear. Though in the above photo it appears that with the tie rod end being spaced down, it may avoid hitting the subframe.
This is something I’m glad I noticed now. Once I finally get all my gear in, I’ll need a 90 degree bend with a banjo bolt on my brake line to offer clearance, otherwise shit could get messy stat! Cutting part of the sway bar mount is an option, but I don’t think it’ll be a good idea due to the design of it. Though I could get another piece made or brace it.
So is the R33 front conversion do-able? Yes it is, all that’s really needed is the castor rod to be extended and the LCA re-modified. If I went the Ikeya Formula style LCA that could do the job too and would probably be a better option.
However, I have abandoned going down this path. As I have just thought of a much simpler way to go about this.
Stay tuned for part III!
The quest for more – Part III - VIEW ON THE BLOG
After the discoveries that my original R33 knuckle conversion plan needed more work. I went back to the drawing board and weighted up other options.
It wasn’t until I put a Stagea/GTR knuckle and R33 knuckle side by side where I started getting fresh ideas.
The main issue was the fact that the 4WD LCA uses completely different mounting system to RWD. I thought about things like adding some sort of ball joint, but with the LCA being a cast piece and not much room to do so, I scrapped that almost instantly.
So then I thought some more, and looked closer at both knuckles.
Sooner or later I finally came up with something that should work and be quite effective. It essentially consists of merging the 4WD knuckle into the R33 piece. The LCA mounting point will be cut and welded underneath the LCA mount on the R33 knuckle.
The spindle from the 4WD unit will also make its way over. Which will mean this will be a direct drop in part. (The spindles on the 4WD unit are larger, thus needing different bearings between knuckles).
There happens to be a difference in height between 4WD and RWD knuckles, so I’ve requested for steering arm point to be as low as possible. That paired with the LCA mount underneath the RWD section, should bring it near the original 4WD knuckle height, (RWD is significantly shorter). But with the hub roughly 20mm higher, correcting roll centre to some degree.
All the knuckles are on their way to JDI Fabrication, for Jake to work his magic.
Once they come back, they’ll make their way into the Stagea. Where I’ll need to design a bump stop and figure out what to do with my brake lines. I’m expecting to set up the Stagea for some pretty crazy lock. So far it looks like I have all the ingredients to do so. The 4WD subframe is quite an interesting piece, and appears to offer more inner clearance than RWD versions out of the box.
It also appears that the steering rack is quite a bit closer to the LCA on the 4WD subframe (top) compared to RWD (bottom). Which could potentially mean I shouldn’t have any issues with going over centre/binding.
Everything seems super promising on paper, I can’t wait to see how well this actually goes down.
  • 5 weeks later...
ALL GOOD THINGS COME TO AN END - VIEW ON THE BLOG
I’m sure word has travelled across the internet, that the Stagea has recently gone to a new home. While I was undecided whether to part ways with it or not over the course of a few months, I finally decided the time had come.
Everyone remembers my horrible R33 skyline that f**ked my life. Well I’ve still been trying to recover from the debts that it put me in. Whilst if I was smart enough I shouldn’t have built the Stagea as quick as I did. But not having something to track for so long really got to me. I think about it sometimes and regret using the money I got back from parting out the Skyline, to build the Stagea to a degree. But hey, you can’t change the past.
Anyway, along with that I’ve got other things going on which quite frankly are more important than a piece of metal on wheels. With all that said, it wasn’t an easy decision. I had never intended to sell the Stagea and if I wasn’t stuck in the rutt that I’ve been in for a while then it would still be in my possession.
I guess what gets to me the most is that it was oh so close to being ‘complete’ but I guess that is part of the parcel.
The new owner, Brad contacted me soon after I had advertised it for sale, we teed up to meet on Saturday. The cash was handed down, and the papers were signed. The Stagea was no longer mine.
Brad vowed to take good care of it, and I believe him. I’m glad it has gone to a good home where some will appreciate it for what it is. Maybe one day when I have my priorities right and a wad of cash burning in my pocket, I’ll build another Stagea.
Cya later LOLVO!
  • 1 year later...
Yes it's adams old stagea. Was great when he had it and it's gone down hill again, even after he bought it back and fixed it again.
When ever it gets sold the new owner wants to flog it off for more than they paid. New bloke is the worst, seen it for sale everywhere!
  • 6 years later...
Oh man I love this thread. I only just found it and wish more of the picture links still worked, or the website he linked was still up. Definitely some big inspiration for my stagea!
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
