R34 Gtr Apexi Power Fc & Commander
Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice. -
If this is required due to the installation of a GTR hood on a GTSt, the existing GTSt one can be modified to fit. -
is it common on RB25det motors that the exhaust manifold nuts become loose overtime? I was inspecting some stuff and noticed that a couple of nuts were so loose that I could literally turn it by hand. Everything is stock on exhaust side unless when they installed the dump pipe they had to remove the manifold for whatever reason. I'm surprised the boost leak didn't show up on the test lol.
