nismoid pls dont close this thread. i had my oil pump fail today on the dyno at just under 400awhp and i am hearing conflicting stories that the ross balancers can do this. i was told that an ati or a new stock nissan balancer would be much better. has anyone had any oil pump problems with a ross balancer fitted ? what power were u running ? i know of the early 32 oil pump drive probs but i did not think that they were this weak, and have not heard of them failing this early in the game. especially with a good brand new balancer. opinions pls.
https://www.sau.com.au/forums/topic/363400-r32-gtr-oil-pump-failure/
really, this seems like the norm,
I hate to say it, but an old oil pump and narrow oil pump drive with over 7500 rpm and this is where the problem usually occurs.
bit of a hit and miss really, some seem to survive, some don't.
sorry to hear though mate
I have never heard of a Ross Balancer destroying an oil pump but then I don't know much - would be interested to hear of anyone who knows/thinks different. Sounds like you need a crank collar and a brand new pump.
people kept telling me after the failure that this is a problem with ross balancers. but now im not so sure because so many people use them. surely a brand new balancer of this brand cannot be attributed with the pump failing ?? ill make some calls tomorrow to get as much reliable info as possible. just snapped a half inch drive trying to remove the balancer aswell, happy days :)
My old GTR motor had a stock balancer (balanced with the new bottom end) and it was running fine, it was then switched to a ATI balancer (the guy who purchased my car got the wrong one for a R33 GTR and it kept flicking off power steering belts) so he changed to a Ross balancer.
The motor then proceeded to lunch itself, shitting a oil pump, cracking the block as well as damaging the bearings.
The motor was fine for 2 years running between 500-575rwhp and then suddenly after changing to a ROSS balancer it broke in very short period of time!
Not blaming the ROSS balancer and it may be a coincidence, but food for thought :)
If the engine is balanced correctly you shouldn't have a problem.
Remember, crank, rods, pistons, harmonic balancer, clutch and flywheel all need to be done
Incorrectly adjusted timing belt, power steering and a/c belts don't help either.
Hitting the rev limited is also a sure fire way to break 32 pumps.
I feel the problem was not the balancer but most likely installation.
Matt
a question for you.....is the balancer gripping on the crank/woodruff key correctly?reason i ask is that is ive seen a balancer that had stripped the woodruff key and was loose on the shaft,the bolt bound up its own thread and refused to come out(it wound out 2 turns then was rock solid)This engine had a crack in the pump gears because of the balancer wobbling back and forward like a dick in a shirt sleeve
Edited by ylwgtr2
^^ nah its tight trust me, tested the thing b4 i put it on. then done the vvft procedure. it fitted very snug, excellent fit. any hoo with all the stories im now scared to use this thing with the nitto pump. the ross is probably an awesome balancer, but i dont know that.
I'm looking for something more factual in this thread. A stock oil pump broke at revs, a common occurence especially with stock oil pump gears and stock narrow pump drive. You blame the balancer. I've gone to the expense of the ATI myself, on the advice of the experience of my engine shop, but unlike the stock oil pump breaking I haven't seen as much specifically caused by the balancer you mention.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
