wrecking r33 gtst car is black and only has rear end damage.
for sale
all seats (excellent condition) -$250ono
both doors (complete) -$100 each
bonnet (some slight scratches) -$100
front guards -$100 each
series 2 front bar (some slight damage) -$50
series 2 headlights -$150
washer bottle -$30
overflow bottle -$30
brake booster -$50
brake master cylinder -$40
clutch master cylinder -$40
brake and clutch pedals and mounting brackets -$40 each
standard intercooler and piping -$50
standard dump pipe and cat -$60
tailshaft -$100
all seatbelts -$40 each
centre console -$50
have many interoir parts and odd parts here and there just pm me wat your chasing and i can let you know just too much to list
3.5 inch trust cat back exhaust
excellent condition
$300
rb25det motor loom and computor
motor serviced every 5000 k's with castrol edge oil and additive
compression 174 on all cylinders
vehicle had 36000 kms on it when motor was pulled out to be replaced by a fully built engine
excellent condition
$1900ono
rb25det gearbox
changed oil very regularywith aditives
excellent condition
$1400
r33 gtst diff
oil changed regulary with additives
excellent condition
$550
https://www.sau.com.au/forums/topic/363409-wrecking-r33-gtst/
  • Replies 47
I'm after the front inner guard flaps (the cover flap thing that covers the front wheel arch from the front bar. Let me know if you have it and how much you want and I'll take it.
Thanks.
front bar has minor cracks and stress marks, i still had it on mine but replaced it with the aftermarket one on the wreck i bought, has lights, gtr style grill, is black, has no covers
dose not have a sunroof
lights are in good condition could use a buff tho, but they are on hold atm for a buyer
Dont suppose you would be willing to sell the Harmonic Balancer off the engine? 0433 276 116
Also after the intercooler pipe which goes from turbo outlet to the hole in the chassis
Edited by Tuscani
