Nissan Silvia S15 JDM 2001 model
Custom midnight purple with flared guards. Sports suspension, Ball bearing Garrett 2871R turbo, 120xxx kms on the clock, car is excellent.
Item Summary: 2001 S15 NISSAN 200SX SPEC-R, custom paint midnight purple paintjob with flared guards.
Odometre: 120,000 kilometres
Asking Price:$15,500
Condition: Used
Reason for Selling: time to buy a house, im getting old -)
Delivery Methods: PickUp
Contact Info: 0421 864 698 sms/call for fast response or feel free to PM
Extra Information: I honestly spared no penny touching up this car and making it a perfect car to drive. Car has custom paintjob done, midnight purple, with flared guards. Service just done, new brakes, new rear discs. Compression tested 4 months ago, recording 150 across all for, any test welcome, no test pilots/time wasters please.
Car will come with these extras: (all these goodies will come for the price above)
-Ball bearing garrett 2871R turbo only 15000 KM old ($1500)
-Front mount intercooler($450)
-Trust Radiator($800)
-Blitz Boost gauge($100)
-Blitz Aftermarket turbo timer($50)
-Upgraded gearbox to 5spd s14 gearbox($800)
-Exedy brass button clutch($1000)
-New from+rear brake pads+rear discs($400)
-Tinted windows($300)
-Custom midnight purple paintjob+flared guards ($4000)
-Lovells suspension (sportier ride and slightly lower but LEGAL height)($400)
-Bosch fuel pump ($200)
TOTAL VALUE: $9900 approx!!!
Other important information:
-12 months rego
-Wheel balance and allignment just completed, perfect drive
-Serviced just done (done every 6,000KM)
-Alarm and kill switch
*****$15 500 for above...HOWEVER....*****
I also have these parts available for extra on top of the asking price:
-ISC coilovers, barely used (extra $700)
-Clarion DVD player+sub (extra $350)
-Full exhaust with Varex muffler, which you can quieten down (close off) using a remote switch (extra $350)
-Denso 650 injectors (extra $300)
-Apexi PowerFC (tuned for above) with hand controller (extra $600)
-Z32 AFM (extra $150)
-Blitz Boost controller (extra $150)
-Rays 18 inch wheels, with almost new tires all round, front 225/40/18, rear 245/45/18 (extra $1500)
-Aftermarket tail lights (extra $100)
Bad points (every car has something):
-Damaged guard (easy repair)
-5th gear has developed slight crunch but if gear is changed gently, has no problems.
-Willing to swap for a small, cheap car plus cash my way.
https://www.sau.com.au/forums/topic/363422-nissan-silvia-s15-jdm-2001-model/
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
