I cleaned the AAC and AYC, replaced coil packs, fuel pump, fuel filter, all the lines.
My thoughts were that it was fuel related (hence a stab of the throttle to pick the fuel pressure up) but it could just as well be not enough air, so no, i'm out of ideas too man :D.
  • Replies 133
Posted Images
Yeah that's what I thought initially too. But I dropped my fuel line off whilst it was cold and there is still furl there so it's not draining to tank. An performance isn't hampered so no starvation. I replaced my ayc, cleaned the aac, changed to a oem bov, cleaned the afm, adjusted the idle, calibrated the tps, checked the coolant sensor, checked for boost leaks, replaced the fuel filter and lines.
It's got me stuffed. I'm just going to start replacing things now. First up is aac and coolant probe.
have the cold start idle issue too. Car pretty much stalls as soon as it fires up if i dont blip the throttle...
When i had aftermarket injectors, z32 afm (with plug) and tune car would fire and not struggle...
So its either the injectors, afm or tune in my opinion...
I've had my rb20 stock injectors cleaned before fitting in and still have cold start issues. So that could mean afm or tune...
  • 6 months later...
Any ideas yet? Replaced my injector o-rings as one was leaking, Removed and resealed all joiners on the intake. Cleaned the aac again. Adjusted the throttle. Still have the issue. Funny thing is from time to time it starts beautiful cold.
Nissan Fast AAC valve.
I have pulled apart the iacv-aac valve (23781M in picture) and cleaned that.
However ive never heard of the air regulator? (22660M)
Perhaps the problem lies with the air regulator? Have you cleaned/replaced that before?
What they do is in the name. AAC Auxilary Air Controller and IAC Idle Air Controller. And i have replaced the IAC and cleaned the AAC. But i don't believe its either as once started it idles perfectly and does not faulter when load is placed on and off the engine (A/C). Im thinking electrical as i have noticed the first few cylinders firing sound almost like its mis-firing. Then once it gets up to speed ( >300rpm) it settles itself down. Ive also noticed when its cold there is a surge as soon as boost is coming on. Hence why im thinking either coil packs or maybe o2 sensor.
No not yet, but i have replaced it with a walbro 260lh/hr pump. But i don't believe the issue to be fuel, as i can prime the system a few times and make sure the system has full pressure then start it with the same issue.
Thought i would keep this going as a record.
So far i have
Replaced the IAC
Cleaned the AAC
Checked for boost leaks and replaced a few hose clamps
Resealed the injectors
Replaced the fuel filter
Replaced the fuel lines
Replaced the fuel pump
Replaced the vacuum hose
Adjusted the tps to 0.4 at idle and 3.97 at WOT
Thought about setting it on fire
Bought some petrol
Removed the turbo timer
Removed the immobilizer
Replaced the o2 sensor with a new ford el type
Replaced the spark plugs with BCPR6E -11 gapped to 0.8mm
And still nothing. I played with the tps again yesterday and moved it a heap out of wack. I found that it would start beautifully but between 2-3k rpm it would splutter and stall. So i would assume that the idle was switching around there. With that i would say it is a TPS issue?
Edited by beemae30
In Townsville. And no i haven't tried another ecu yet. Thats the strange thing even with the throttle held open it still struggles to fire for the first few revolutions, then once it fires a few cylinders it picks up. Otherwise with the throttle at idle it takes about 5-10 revolutions of missing before it picks up to normal idle otherwise it stalls then will fire and run to idle straight away on next turn of the key.
Ok so took it for a drive today for an hr or so. Hesitation between 2-3k is gone since i readjusted the tps back to how it was (0.4v at idle, 3.97v at WOT) But now the idle is fluctuating and i can't adjust the aac. So i think ill just buy a new TPS and AAC and see what happens
Try crimping the fuel return line after the fuel pressure reg when starting to raise te fuel pressure. the reg may be getting soft.
With the tps if its not set correctly it may not be in the idle maps. Try lowering it to .35 or so
Well I don't have anything with me ATM to check the tps again as I'm in Mackay for inductions. But it's definitely set to 0.4v to 4v. I've also noticed another sympto that's only just started, when i drive it cold , she sometimes misses until the first sign of boost or i give it more then 20% or so throttle then it's ok but it doesn't like driving at partial throttle occasionally. I've only noticed this since I replaced the o2 sensor but at the same time i played with the tps so im hoping fpr, maybe injectors running less pulse width cause of altered fuel maps = more fuel fighting fpr? Which bring the issue on just before boost? I dunno clutching at straws here. But it drove for 400km last night no worries
Edited by beemae30
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
