1. iPhone 4 16GB White
Currently locked to three but can be officially unlocked through three.
New in condition, not a single scratch.
Bought a SGSII so not needed.
R. $700
I. $770
2. Google Nexus One
Unlocked from the US. Running official gingerbread 2.3.4.
Have all accessories and box.
Trackball a bit dodgy, sometimes doesn't work but it's a touchscreen phone so not much of a problem.
Screen has no major scratches, body/corners have scratches etc. it's been used with love. Will post photos later.
Can inspect if you're in SA.
NOTE: Will not send this phone till i get my SGSII which is being sent from the UK on monday.
R. $230
I. $330
3. iPhone 3G 16GB Black
Have original box, charger and cable, no headphones.
Back has usual scratches. No cracks or anything though. Screen is pretty good no major scratches etc.
"Problems":
This phone was locked to Optus and i jailbroke it to unlock it. Worked absolutely fine once i did that. Was working with 3.
Tried to restore it yesterday in preparation for sale which succeeded now it asks me to plug it into iTunes to activate and when i plug it into iTunes, iTunes just freezes. I can't be bothered wasting my time trying to unlock it again so my loss your gain.
R.$100
I. $200
Edited by occxlr8ed
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
