post-69249-0-14918300-1304766105_thumb.jpgpost-69249-0-18214700-1304766054_thumb.jpgpost-69249-0-11484300-1304766026_thumb.jpgpost-69249-0-27999600-1304765977_thumb.jpgpost-69249-0-26074900-1304765943_thumb.jpgpost-69249-0-97088000-1304765927_thumb.jpgpost-69249-0-75608200-1304765899_thumb.jpgpost-69249-0-98950800-1304765784_thumb.jpg post-69249-0-14918300-1304766105_thumb.jpgpost-69249-0-18214700-1304766054_thumb.jpgpost-69249-0-11484300-1304766026_thumb.jpgpost-69249-0-27999600-1304765977_thumb.jpgpost-69249-0-26074900-1304765943_thumb.jpgpost-69249-0-26074900-1304765943_thumb.jpgpost-69249-0-97088000-1304765927_thumb.jpgpost-69249-0-75608200-1304765899_thumb.jpgSELLING MY BELOVED RACE CAR Its a 1990 gtst skyline now fitted with a wolf ecu with hand controller,740cc injectors,custom alloy sump and head to sump return lines, remote engine cooler, engine all balanced reco head, all new bottom and rebuild, N1 oil pump, oil surge tanks, RB 25 gear box, GTR braking system, coil overs, rollcage, auto metre gages, interior strippes and 2 packed, big exhaust system, 60 litre fuelfuel cell and bosch fuel pump, locked diff, 6 point racingharness, runs E85 fuel-same as V8 supercars just been dynoed and made 350hp on 9lp boost at the rear wheels, durezza race post-69249-0-98950800-1304765784_thumb.jpgtyres,235x45x17s on light weight 17x8 and 17x9 rims comes with spare race tyres, has tein coilovers and comes with spares, has negative frony cambere and handles awesome, very competitive car and has won class championship 2 years in a row,engine only 2 meetingss old, fibreglass front bumper and spoiler bolts on with zuis clips for easy removal, 2 spare high flow ball bearing turbos,one needs a bearing but these turbos will take500hp plus, huge front mount intercooler, alloy radiator, remote oil cooler and filter setup, huge oil catch can,bolt up wheel spacers, endless brake pads, boost gauge, front and rear alloy strut braces, adjustable front radius rods,splitfire coil packs, dry cell battery, club sports sedan championship winner 2009-2010, very regretful sale, spent way too much money on car, nearly 30k, chasing $15,000. I can be contacted on 0488954213. Only serious people inquire please
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
