A mate has offered me his bmw that I absolutely love and I need to answer him by lunch time to buy it. So my 34 is up for sale as I hopefully want it gone today so ring my number 0401 184 069 DO NOT PM ME AS I NEED AN ANSWER SOON!!!!!
-1998 Model
-108,xxxks - I work away 6 months a year so I rarely drive it but as i said I love my mates beemer and would prefer to have that sit around not been driven lol
-Silver
-Sunroof - Hard to find
-MINT R33 GTR Wheels with 4 brand new tyres. I do have a 2nd set of wheels I can put back on for cheaper
-Recent wheel alligment and replaced some of the bushes in the front end with Nolathanes
-Mint Interior
-Manual (changed using R33 GTST box with approx. 95,000ks on it)
-Brand new chromolly flywheel that is factory weight ($440 rrp)
-Exedy heavy duty clutch with the 10,800N pressure plate - http://www.kudosmotorsports.com/catalog/ex...yline-p-26.html
-Nismo gearbox mount
-All brand new Nissan supplied bolts were used for the conversion
-Australian Standard Black wired alarm with anti-carjacking
-Factory Xenon headlights
-Brand new o2 Sensor
-All the usual options like TRC, ABS, Electric everything as usual
-Blue LED dash lights
-Sony A/M deck with Bluetooth and Ipod Connectivity (Blue deck to match in with the dash lights)
Details on manual conversion:
I did a full manual conversion almost right on the 100,000k mark with the intentions of keeping and developing it. I have used the original dash cluster with the manual face on it so its the original Ks (have the spare manual cluster that I stripped to keep my original one in there), used all original R34 parts, Clutch Master is a brand new Nissan direct item and the pedals are R34 items not modded R33 ones. I also fitted a brand new Chromolly flywheel (factory weight) and Exedy clutch with a heavier clamping load. Over $1000 alone there and the package from what Exedy have said will handle a slipping and good power which is what I intended.
I drove this to Phillip Island for the Moto GP in October and the trip there and back she didnt miss a beat. Fuel economy was also very good which surprised me as the auto was terrible on fuel. Sitting on 110ks in SA and 100ks in Victoria I was averaging 550ks+ out of a tank so around 10L/100ks as the tank only looks to hold around 55 litres but someone feel free to correct me
I will also throw in with the car a FMIC kit I bought for the car. I do have a complete HKS GT2530 turbo kit as well available for an extra $1000 to the buyer
Price
$15,000k as is with the GTR wheels and a turn flow cooler suppied or I can fit if wanted OR $14000 with the original wheels that came on it
http://img29.imagesh.../img0153ii.jpg/
http://img340.images.../img0159sa.jpg/
http://img202.images.../img1994v0.jpg/
http://img607.images...i/img19960.jpg/
http://img827.images...i/img19990.jpg/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
