hey all,
i baught a car from OH Performance, so called performance, now there shut, and the car has bad compression on cylinder 6.
im pretty spewing, theres nothing i can do but fix it.i was just going to ask if fixing just cylinder 6 is pricey and risky.....
i dunno what my options are here. fully forged rebuild im looking at 13ish. i wanna spend 7 including dash 5s.
https://www.sau.com.au/forums/topic/363468-oh-performance/
2nd handy u recon, what do they cost? i got quoted about 2gs to fix the cylinder
Find a used motor with warranty, Japan autos sold me mine and Im very happy with the condition.
You will save a packet and have the car back on the road asap.
GL
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800123
You need to think ahead, how much power are you going to be chasing, if you just want something with a bit more than standard the a second hand motor might be the go (just remember most of them only come with a 30 day warranty) if you want to wind boost in a get some good power out of it or you want to use it at a race track then you would be better off rebuilding it so you know everything is good.
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800130
Well the owner of OH ended up hitting a tree and is no longer on this earth - hence the shop has shut i believe.
However you can't really just fit one cyclinder. Nor will you get away with it all for $4,500 (taking into account turbo price/fitting).
So as Scott said, the only way to meet that budget is get a 2nd hand R33 motor, change turbos, bolt it in.
-5s in that case will also be the wrong choice as you will not be able to fully utilise them on a stock motor as reliability terms would suggest to be more conservative as you are obviously low on budget/funds.
Even @ 4.5k you'll wont even get there TBH.
2nd hand motor, installed, turbos (id say -9s) then ECU/tune/clutch/AFM/Injectors and everthing else that goes with it.
Will come to a lot more than 4.5k
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800165
well im looking to make 270-280kwatw realisticaly and i wanna max budget 8, 9 maby. what turbos do u suggest for this? also were do u recomend buying a second hand r33 motor from, i cbf getting a dud again. also off the top of your head how much can u buy one for without turbos? could i sell my motor? cheers for all that info to mate helpful as
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800172
If thats all the power you want, Garrett -7s mate.
The -5s will make 380rwkw or there abouts, so totally not what you want.
Just have a search and a read through the dyno results thread, you'll soon see what you need in terms of parts.
For 280rwkw you'll get away with stock injectors and AFM so a good saving of $$$ in that respect.
Motor wise - no idea mate. I've never purchased one but there is already one place mentioned so far :)
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800176
and as for selling yours, lots of people are after a complete rb26 to rebuild at a decent price to put into any thing and everything, if priced right (go through the for sale section and see what they have sold for) you shouldnt have any problems finding a buyer.
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800180
cool man thanks for that, ill have to look into, just to double check fixing a cylinder isnt worth it is it?
so japan autos... if anyone else has good feedback for another place please let me no, cheers
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800185
not much in it really, if the bottom end needs a rebuild the top end is only worth $1000 give/take.
Bottom end really isn't worth much at all in rebuild condition
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800195
Send engine to Paul(R racing or something) forged bottem end rebuild around 6k nisture your ecu for $220 + around $500 for tuning. Stock injectors and stock AFMs should be fine for your power level.
Find a set of r34 N1 turbos seen them go for 1k and if you can afford it nitto oil pump.
If you can remove and refit your own engine you will save a heap of $$$.
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800221
Be it myself I would change plan to -7s, get a good used motor, do a 100k service on it including a clutch, put it in and leave it at stock boost until I can afford to do more.
Admittedly that would require me accepting a final outcome of 300kw atw and no more, yet that would also overcome future overheads of the endless list of modifications needed to justify the use of -5s.
I would agree with -9s as Ash said however am of the opinion they warrant AFM's + Injectors when -7s can be utilised (almost) in full without. Thats a saving of ATLEAST $1500, based on experience.
Its the owners call, but a great deal more research is needed before any decisions are made.
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800253
You can also get -9s without upgrading AFM and injectors, just keep the boost level down.
In your case, get s/hand motor, get wreckers/seller to do compression motor if it is within 5-10psi of each cylinder go for it.
Last time I went to OH, it changed to panel beater now, was couple of weeks ago.
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800303
all i can find is 2nd hand motors for like 5k. id rather rebuild mind forged, bite the bullet and spend the extra and do it once and right.....
cbf getting another 2nd hand and then later on problems..... i think 13g will do it all....
https://www.sau.com.au/forums/topic/363468-oh-performance/#findComment-5800356
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
