Just trying to diagnose some possible running rich issues. After replacing my 02 sensor, my town economy increased slightly (down to 12.5-13L/100km) but my 96 stagea still was using 12.5l/100km on the freeway which seems odd. I figure its running rich since theres tailpipe soot, and the exhaust pops when you rev it in idle.
Now to the ECUtalk oddity: it has a overall trip litre/100km measurement which is always optimistic. eg if I used 12.5L/100km, as measured at the fuel pump, ecutalk will read 10L/100km.
So where is the fuel consumption measured from? Could this contribute to too much fuel being injected?
https://www.sau.com.au/forums/topic/363477-ecutalk-and-fuel-consumption/
Ecutalk from my experience uses injector size and injector duty cycle to calculate fuel consumption.
As for consumption itself, get yourself a wideband AFR kit or borrow one. Will tell you how rich is it really running.
yeah ECUtalk calculates the fuel economy based off injector size and ecu mapping. if your economy is worse than the ecutalk is calculating then either the fuel pressure is higher, or the injectors are fouled (being fouled doesn't always mean it will be injecting less fuel. it can mean that is actually injecting more fuel as the injectors may not close properly, etc).
the other thing that may possibly be causing the oddity is that the odometer might not be working properly, so the KMs you are using for the calculation are actually more than what the ecu is reading (and what you are actually doing). if you, or someone you know, has a gps, use it to keep track on the distance you go between fill-ups (most will have trip logging. in the case of most Garmin ones, just tap the speed window on the map screen and you can reset trip totals from there).
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
