Compaq Presario 2543AH P4 2.8Ghz,
512 DDR Memory, 40Gb HD,
Firewire, 3 USB ports, infra red. 15" screen, 56K
modem, DVD Burner, T10/100 LAN, TV OUT,
64MB Radeon Video card shared memory, MS XP Home
Edition.JBL speakers. Has 2 marks on it
Laptop is Refurbished by HP and has 4 month Warranty. Still sealed
and in box Make me an OFFER. Pics available.
Make a Reasonable offer.
https://www.sau.com.au/forums/topic/36349-laptop-with-dvd-burner/
"Laptop is Refurbished by HP and has 4 month Warranty. Still sealed"
english!! do you speak it?
Refurbished does not mean brand new. one mark came from a knock during transport and the other was how it was when refurbished.
PRICE $2100 or nearest offer.
You get 4 month warranty.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
