Hey Im selling my Holden vs 1997 5LT V8 ute REGO TIL MAY 29 2011
It has the following -
- 5 liter v8
- Pace makers extractors and FULL costume 3 INCH exhaust system ITS has a real GRUNT
- 276 LUMPY cams
- 2,500 mini spool
- Tub liner
- Tarp
- Shift kit auto
- 4.11 diff believe to be welded as well
- HSV vs interior side trims and seats and steering wheel
- HSV 18inch wheels with fairly new rubber
- Bt1 v8 computer
- Legal tinted windows
- Tow bar
- King springs suspension
- New coil pack
- New 9mm leads
- New ngk spark plugs
- New Oil and filter will provide extra filter
- New control module
- New SS imitation red molds and vx ss original badges
- New SS big mouth air induction
- New transmission service (including oil )
- New engine mounts
- New wiper blades
- New alternator
- New battery
- New starter motor
- New key barrel and key
- New head light globes pretty bright
- New hand brake
- New tail shaft center bearing
- New starter motor
- New cd mp3 aux Kenwood cd player and Cadiance 6inch 2 ways speakers sounds nice !
also do have two spare rocket covers and gasket.
can provide receipts if i can find it there all been changed with in 3 weeks you can look and see for your self there all brand new NO second hands
had auto elect do all the electrical things and very happy with the job .
THINGS NEED ATTENTION
- tail shaft needs to be uni joint
- diff needs to be replaced or reconditioned
- ss fog lights need to be wired up and temp gauge isnt working assuming sensor
- roof lining needs a new one old owner ripped it off
- rear brakes need changing
price $7000
i want a quick sale ! selling cheap ! cash only no swaps sorry
car NEEDS a tune due to having modifications it should get easy 180kw to 200 kw with the work on it at the moment.
So if you want to go work with a grunt and looks with heaps of extras DONT think twice your really getting a bargain
WILL SELL WITH REG BUT NO RWC! BUYER MUST PROVIDE OWN THANKS if want a view your more then welcome to view in Broadmeadows Melbourne Victoria contact harry on 0411 401 942 thanks
Edited by hudaz
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
