yeah mine too, im talking from a standing start. hold the foot brake on (not the parking brake) and floor the throttle, mine will start spinning about 3 seconds later. as soon as i let off the brake, the fronts grab and the occupants of my car get whiplash lol
  • Replies 57
Posted Images
I don't get it though...I've dropped it down to 2nd gear when i'm at say 60 and planted my foot. Can't get the tyres to chirp. Car just takes off like a rocket...
Probably because your stall converter flares like mine till about 3,400rpm therefore your have more of a slingshot rather than a chirp....unless of cause you have locked it.
i think the quality of your tyres are actually 'too good' to do it..
that and i have a shit suspension set up.
i reckon it will go away with the 19" and BC's(when I get around to owning them)
and yeh, i have a torque converter lock up clutch locked on mine...
With regard to what Iain is saying, I'm not sure "easier" is the word, because it happens at much higher speeds and loadings.
I think because it is so much more consistent, you can invoke certain handling traits, like oversteer, much more safely; in that you know how the car will behave every time.
lol i know how to drive you ass hole..
i think one of my front struts are blown. its clunking every now n then.
so my next pruchase after these wheels are on are the BC's. then i can drop it on its ass again lol
On topic, (calm down ladies) I dont think you need the restriction removed unless you get a highflow as I can bag the wheels up now at takeoff (stock turbo), it is very different with a highflow and most likely gets worse the larger you go. Most likely I will hate the Garrett until the remap is done.
sorry i didnt mean you cant drive, but youll need to adjust the way you drive as the car handles differently.
dropping it on its ass wont help handling BTW
lol i know it wont help handling. i was joking.. mines dumped right now and its a frikin pain. shouldve listened to scott lol
Nice work Leon!
I asked a mate to look into this also, but after everything thats gone on, and your testing, its clearly so much bigger than we all thought!
It's funny how nothing seems easy on the M35. Maybe we should be all driving C34's :laugh: .
I'm now considering this a challenge and will pursue it to it's completion, be it successful or not. With knowledge comes (power?) the ability to find solutions to other needs/wants/problems that may crop up in the future, plus I love to learn.
It has also occured to me that if I have the ability to open the throttle a little more at say 20% (where I sit most of the time on the freeway) it will make the engine more efficient. If, as a byproduct of this, it reduces the injector pulse width with no or little change to cam timing I could have a sweet spot set up for a lean cruise mode. The point being, even if I'm not 100% successful in beating the throttle restriction above 80%, there could be an indirect benefit of this R & D work.
Is the throttle restriction in all gears and at all speeds or is it just first gear and under roughly 30km/h as it feels?
Perhaps it would be possible to trick the ecu into thinking it was in a higher gear or already going faster whilst still in first?
Does the throttle body ever open 100%
I like the way you think -outside the box. I'm not sure if that is a viable solution but I will ponder the implications & anything else related that comes to mind during the week. It seems that almost everything in our factory ECUs are tied to something else. Thanks for your input Steve. Oh, and max throttle I've ever experienced according to the informeter is 85% I think. In the last couple of weeks it's been nothing over 80%. Again, it's so many other factors which determine what the ECU allows you to do.:mad:
As for you other guys - you crack me up :rofl: It doesn't take long to degrade into a free-for-all lol.
Lol, youre all gay and im taken, sorry. :)
as I quote you saying.
"he wants to pay me in beer, I dont drink beer.. if he offered pussy it wouldve been another thing"
the look on your Misses face was priceless
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
