  • Replies 57
Posted Images
It's funny how nothing seems easy on the M35. Maybe we should be all driving C34's :laugh: .
I'm now considering this a challenge and will pursue it to it's completion, be it successful or not. With knowledge comes (power?) the ability to find solutions to other needs/wants/problems that may crop up in the future, plus I love to learn.
It has also occured to me that if I have the ability to open the throttle a little more at say 20% (where I sit most of the time on the freeway) it will make the engine more efficient. If, as a byproduct of this, it reduces the injector pulse width with no or little change to cam timing I could have a sweet spot set up for a lean cruise mode. The point being, even if I'm not 100% successful in beating the throttle restriction above 80%, there could be an indirect benefit of this R & D work.
I like the way you think -outside the box. I'm not sure if that is a viable solution but I will ponder the implications & anything else related that comes to mind during the week. It seems that almost everything in our factory ECUs are tied to something else. Thanks for your input Steve. Oh, and max throttle I've ever experienced according to the informeter is 85% I think. In the last couple of weeks it's been nothing over 80%. Again, it's so many other factors which determine what the ECU allows you to do.:mad:
As for you other guys - you crack me up :rofl: It doesn't take long to degrade into a free-for-all lol.
here is something to add to the many curve ball's....the throttle stepping and open% may also be changed buy the temp sender on the AFM!.....density of air and all that crap.....I hope you crack this one Leon. Another thought as our ECU is similar to the AT RX8 in the way it control's everything maybe there might be some info on this within the RX-8 forums somewhere!
anyway just my thought's and awesome work Leon!...don't you just love drive by wire!
I think you are spot on and there may well be a couple of other parameters thrown in for good measure! If I had to determine exactly what the ECU looked at to open the throttle a given amount, I'd need a lookup table far bigger & complex than I'd be able to put together myself with the resources I have.
I'm guessing now, but at this early stage I think I'd be lucky to get maybe an extra 10% total opening consistently. Another few % may come with the other parameters that will be outside of my control.
I'll just sneak up on it tho. I little research, a bit of measuring, a LOT of trial & error & see what eventuates. And no, I don't particularly love DBW :glare: .
give me a full ecu wiring diagram in english and ill sus out whats holding it back from opening up the throttle....... ie: all sensors attatched to the ecu etc etc
Wiring diagram.. as in which pins do what? we've gone one of them thats fairly complete, and I should be able to do the rest if theyre required? :)
actually a diagram wont help with out the software to be able to access the ECU to see the program that is running.
the wiring diagram will only show whats connected to the ECU and not how the ECU uses the information.......... i was thinking to symplistically HAHA
has anyone spoken to these guys.......... http://www.nistune.com/index.php
edit*** is this the correct ecu for our cars? http://cgi.ebay.com.au/NISSAN-STAGEA-M35-ENGINE-ECU-/270745912798
Edited by WAGON_BOY
Well I have a Stagea VQ30 ecu for $100 if anyone wants it. Someone on this site said that the VQ30 did not have fly by wire throttle so should be ideal for someone who wants to try a mechanical throttle. Its off a n/a engine so ideally would be run with a piggyback and standalone ebc.
How are the cam's controlled on a VQ30? Does the VQ30 ecu talk to the gearbox? What sort of gearbox does the VQ30 have? List goes on.......if only it was that easy! Thanks for the offer and nice thinking!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
