hello all,
i got a bit of a problem, ive got the front door cards off to repair the front door rust. im not sure why but suddenly all the passenger door electric windows have stopped working. the drivers door works fine, but both rear doors and the passenger door dont work. does anyne know where the fuses or relays for the electric windows are?? i dont read japanese so i dunno which ones they are.
https://www.sau.com.au/forums/topic/363574-electric-window-problem/
i had a problem just like that, i took the whole window switch thing out and took the top of it off, incl all the switches, then i used a screwdriver to move the switches while i plugged the board back in. then it started working again, this was a while ago, so im not too sure what exactly happened, this was around midnight after my switches stopped working and i was out in the dark trying to get my window back up
sounds like the window lock button on the drivers door is on? :whistling:
i am pretty slow, but i tried that too. i dunno how nissan wire up the electric windows, but when i used to mess around with holdens the drivers door was wired through its own relay and fuse cos of the auto up/down function. but the other 3 windows were wired through 1 relay and fuse. thats why i wanna find the fuses/relays so i can check if ive accidently shorted it out and blown a fuse.
Edited by Raysboostin
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
