Rb25Det Missing Underload
johnny boii
 Share
hey guys i have what i believe to be a 1.5 series r33 with a rb25det in it
i fitted a rebuilt and hiflowed stock rb25det turbo to it after i did that the stock boost raised from 7psi to 9 psi i had no issues was running fine.
the other day i fitted a turbosmart boost tee into the equasion so i could raise the boost to about 12 psi once i had fitted my fmic
i fitted the boost tee having alot of trouble then realised that i had to take the ball and spring out of it to allow it to run on my engine.
now my issue is that once i raise the boost to about 12psi under wide open throttle it misses and feels like it is fuel cutting like it completely shuts down the engine for a millissecond and comes back on but only half throttle it boosts fine. when i turn the tap fully closed then open it about a half a turn it runs the stock 9psi and drives fine
i have replaced the plugs the day i fitted the boost tee
any help would be fantastic please help ahahah :D
Edited by johnny boii
it'll help but its not ideal and you certainly wont be able to get the most out of the highflow. a full aftermarket computer and possibly z32 afm and injectors, depending on power goals and the ecu, is the best solution.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
