hey guys im looking for some r33 pods for the drivers side door thingo. i have the gauges and just need the pods to put them in then run all the wires and need someone maybe to even install them for me
let us kno
tripple pod would be preferred unless only 2 pods then yeah whatever...
i have 6 gauges to be installed and im thinking 3 on the drivers side part and 3 in the middle or cutting out half the dash and doing a custom install
any ideas guys. upload pics if possible
https://www.sau.com.au/forums/topic/363612-r33-pods/
Just jap sell them in triples but they're universal so I'm not sure how fitment would be:
http://www.justjap.com/store/product.php?productid=17280&cat=325&page=1
And Ebay also has some up currently but they're doubles :
http://cgi.ebay.com....=item2a0da82c1e
http://cgi.ebay.com....=item33675bf1f4
http://cgi.ebay.com....=item2310278ab1
What size are your guages? because the holders are gonna have to fit a certain size.
As for ideas for other mounting areas,if your not a smoker the cigarette lighter hole is a good place but the problem is it's out of your peripheral vision while driving..
If I had the 6 guages i would personally put 2 in the pillar holder,3 mounted in a casing on the dash and 1 in the ciggy lighter hole.
Edited by AAARGH 33
https://www.sau.com.au/forums/topic/363612-r33-pods/#findComment-5802739
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
