  • Replies 149
Anyone used a K&N filter?
Picked one up the other day from ABarn and it is a fair bit smaller than the Ryco (as in tiny!)
Then its the wrong one, just because the thread lines up doesnt mean its right (Thus why we were abusing Aaron before)
ah screw you all i've come to terms with and accepted that everyone will give me shit regardless..
Did you end up getting the Greddy filter?
What was the part number?
It should be 13901104 or 13901204 for VQ engine's :)
nah to be honest i went into CBF mode and just got the Ryco. doesnt bother me as i do changes every 5000km anyway
but the one i previously used is 13901104. little blue filter.
what do you think of the HKS ones? saw a few on ebay for $30//
It is what I'm running at the moment with Sougi.
Will be changing it after 10,000kms (although I might try and stretch it to 12,500) so will let you know.
I tried out a Power Enterprise filer last time and have to say that all future filters will definitely include a magnet in them.
When I looked in the PE filter, I could see quite a few tiny "bits" stuck to the magnet.
As an aside, the HKS and PE filters could be one and the same... just the HKS is purple and the PE is white.
They both state the same features with very similar advertising. Look the same internally and about the same weight.
yeh but where other than ebay(or the net) would you get em?
i know the Drift ones have a magnet, but without an anti drainback valve i dont think they're the greatest of designs..
HKS from ebay.
PE from VisionR
The filter medium used in the Drift filters is shithouse and with no anti drainback = fail.
Edited by iamhe77
LOL
Why do you make it hard on yourself?
Look at the menu on the left of the screen and scroll down to Power Enterprise, then scroll down to Oil Filter.
Alternatively, from the middle section select 'ENGINE" and then "Oil Filter".
You will need the OFII-02A filter
LOL
ok found it!
i shall try this out next service being in perth should only be a few days shipping right.
i'm trying to find an oil leak i have somewhere..around the filter area..
i lose a good 1.5 - 2 litres every service..
probably half the reason im doing them every 5000km.
and this is sougi
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
