Hi guys,
Have recently bought a rebuilt HKS GT2530 for my R32 but im not happy with the lag its got, as im after really good response and im leaning more towards a GT3076R with a .63 rear housing so if anyone has one they would swap with cash adjustment if necessary or sell me i am very keen.
Also if someone can come up with $1200 i will sell the 2530, it comes with the standard .63 internally gated rear housing and also the V Band externally gated housing on it (unsure of size, probably A/R 1.xx something), it has a 2.5" inlet and uses the standard 3 bolt rb20 hotside pipe,
Also have a 3" stainless dump to use with the internally gated rear housing or a mild steel 3" dump for the V Band housing both on the standard manifold so it is a direct drop in for an rb20 or rb25.
The turbo is currently on the car and can be inspected and/or taken for a drive in the car.
Can get pictures on request also,
Contact me on here or SMS on 0408 117 171 for a quicker response.
Cheers,
Daniel.
Yea it will bud cause ill be running a .63 rear housing on the GT30, and i know for a fact that setup will build decent boost sooner than 4500 lol, i could buy a smaller housing for the 2530 but im looking to up the boost a fair bit more than 16psi later on so with the 3076 i will be able to do that .
nah a 3076 won't spool quicker than a 2530 on a lil rb20 , if your getting full boost at 4500rpm then there's a problem , mine was getting full boost by 4000rpm (20psi) . my kkr 430 spooled faster than the 2530 though but reached full boost at similar rpm , have you tried the 2530 with the iw housing?
na i havent tried the IW housing as i would have to cut up another dump pipe just to try it, what size rear housing did you have ? the one on mine is about as fat as the rear housing on my GT35R lol..
I know of a fella running the GT3076 and he had a housing that was A/R 1.06 or there abouts and he then changed to a .63 and said it started spooling by 2200..
And have seen others with slightly laggier results..
If i could get 20psi by 4-5 with the 3076 i would be happy.
Edit: For anyone interested, this is the turbo's resale value:
http://cgi.ebay.com.au/HKS-Turbo-GT2530-RECONDITIONED-S13-S14-S15-Siliva-200sx-/230616218702?pt=AU_Car_Parts_Accessories&hash=item35b1cc3c4e
Edited by DanielH
ah geez mines alot snappier than that, wheelspin is a major issue in 2nd let alone 1st on street tires, i have uploaded a video to show just how the turbo performs on a std RB20, after the wheelspin in 1st gear its wide open from 4k and then wide open from 4k in 2nd before more wheelspin.
http://s162.photobuc...05052011019.mp4
If someone has a GT30 they want to sell let me know, ill pay cash, i also have a complete 1JZ setup i would swap..
Edited by DanielH
Yeah i have a nistune on order, i have many reasons to upgrade to a GT3076 lol, the std ecu idles and cruises at 14.7:1 AFRs +/- .2 and holds a consistant 12:1 under boost so im not worried about my engine, lol.
The biggest reason i have for upgrading from the 2530 is that im already at the limit of the smaller turbo, i can feel it drop off at around 7200rpm at 16psi, which i never had with the turbo i had before that (eBay spec T3/T04E), which i would expect given the small front wheel and housing these turbos have.
So naturally when i get the nistune and get it tuned for over 20PSI im going to have all sorts of issues high in the revs with this turbo.
fairo , will be interesting to see the end result , i can remember going for a run in a 3076 equipped r33 , seemed pretty mental .
Yeah a mate of mine has one on his 1JZ, hits 16psi before 3k and pulls like a mule till 8, and they sound awesome on spoolup :whistling:
I can vouch for the mentality of mine, it's awesome :D esp with a 2" screamer :D
Love it :D
I would actually marry it if I could. I might just get a big gold ring to put around it.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
