just wondering how many ,close to rev limit launches, or on the limiter, a standard r33 GTR box will handle.
its in an r32 GTR with an os giken triple plate clutch, and 330 kw atw.
i recently started going to the strip and love it, but just wondering if the gearbox will survive.
cheers
  • Replies 64
Posted Images
mate its hard to say on these type of things, some could last forever and some could go on your first (depending on km's and alot of other factors) give it regular services and try for second gear lanuches, your syncros will die first usally folowed by first gear, its just like asking how long will a engine last if i limiter bash it, could be years or days, all depends on previous wear.
man.... ive had my gtr for 2 years. 312kw ive done a nite a the drags. and about 100 limiter dumps on the street!! see my sig!!!
they love it hahaha
how long is your string?
your unlikely to break 1st gear, but stuff will wear out, clutches, syncros, transfer case etc, being a 32, are you launching 4wd ?
I would've launched 1st in my last R33 GTR up around a couple hundred times in a few years with no gearbox issues, just a few clutches.. however did smash the gearbox dropping 2nd while rolling..
anyway just go for it, you probably spend more on clutches than gearboxes
my bad, was going off my experience with my rwd not awd, theres no need near redline drop anyways, just get yourself a launch controller activated by handbrake and find the sweet spot rpm just before it will break traction
I'm into the hundreds of launches in my race car.
the most important thing is not to shock it by dropping the clutch cold.
just before launching put the handbrake on and let the clutch out a little to put the drivetrain under load. when the light goes out, drop the handbrake, drop the clutch, floor the throttle and watch it go.
cheers guys,
not so worried now after hearing that,
might just give it hell, and see how long it lasts.
is there any cheapish ways of making them stronger, i have looked at the OS Giken gear sets, and others, but they are so expensive, and the car isnt that powerful. ??
plus its only a street car!!!
cheers guys,
standard box should be fine, just do what Duncan said and pre-load the drive train,
I think the high rev launch is more to not bogging rather than breaking traction...
yep by the looks of the OP's sig he's got a big single, I'm the same, launch any lower than 7krpm and it just bogs down.
get it right and ------
right you are!!!!
anything under 7000-7500 and it bogs down. high boost (1.5 bar)
low boost bogs even nearer to rev limit. (1 bar)
high rpm launch in the wet with lots of wheel spin.
Here's a good one;
Very nice. I still dont quite get the perfect launching technique with the GTR though. Everyone seems to tell me to dump it at around 6500-7000 but this thread says 1/2 clutch with handbrake.
yeah anywhere between 6500--limiter, the handbrake is just to load up the drivetrain before you launch.. on the line put on handbrake in 1st gear, let clutch out a little so it pushes against the handbrake, then clutch back in, handbrake off, don't let car roll back and drivetrain is loaded..right foot down and step off clutch..hang on..:woot:
