I run a k&n panel in mine.. Feels like it can breathe ally better.. and also it's a one off purchase and then afterwards u can just clean them.. I found because they slightly oiled.. When u blow them out with the air gun most the crap comes out pretty easy and back to new again.. But thats my opinion.. Others could feel differently..
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5803761
I've heard from various mechanics and some users that the oil based air filters are not good for our engines,
hence, K&N is not good for the VQ engine is what I've been hearing.
that's why I started this topic.
i'm currently in usa, temporarily. K&N filters cost around $40-$50 brand new but I am hesitant to purchase it for that reason.
The Trust Airinx GT are not available here, they can be shipped from JPN for around $85 USD after doing some ressearch.
so I just wanted opinions on what you guys know about them.
thanks for the replies so far,
i will be waiting for more !!
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5803980
After a few read-throughs online, alot have different opinions.
Pros:
1. Good lifespan, if cleaned and oiled properly.
2. Allow the engine to breathe better then a standard paper filter (Oil is there to attract the dirt).
3. Small gain in power (Depends on the type of engine), if you also change the piping, throttle body, etc.
4. Save money in the long run.
Cons:
1. If not oil and clean properly, it will have bad effects on the engine.
2. Abit of work in cleaning it and re-using process.
So I am abit confussed now as well. :wacko:
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5804540
Technically the oil is not bad for the engine it's more to do with our air flow meter.. As it's designed to read air and not oil..
But yes you do run a risk.. But what mod out there, is there that doesnt have side affects or carry risk.. No guts no glory.. Cant expect everything our way..
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5804626
Jo, you are spot-on on that fact.
I shouldn't have said engine. My bad. :P
Edited by VNS 24
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5804654
Im not a fan of the k&n anymore, i have never had an issue but heard too many stories of oiled up AFM to want to run one again. Id look at a dry type like the greddy. Can get the nismo, mines etc etc. but they are pretty much identical to the greddy in construction but 3 times the price. Greddy seems to be pretty good price wise these days. I have seen them on nengun for around $40+ shipping. So it would end up more around $60 direct from japan, with current exchange rates. Obviousley price will vary with exchange rate etc.
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5805396
Bah, K&N filters are fine :rolleyes: . Don't over oil them (follow the instructions) and you'll be fine.
Been using a K&N without issue for more than a year in my NM35 Stagea now, VQ engine; AFM in exactly the same position.:thumbsup:
They flow stacks more air than a STD filter, and filter more effectively if oiled correctly.
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5805609
Yeah, that would be the main issue for me.
As I've never used K&N panel filters before, I am not that confident to clean it myself yet. I will only install it "AFTER" I make sure my mechanics know about it. Hope it's not too hard or complicating. :P
So Dale, you don't get any AFM problem so far? Do you clean the filter yourself with ease?
Edited by VNS 24
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5805763
Absolutely no issues. Takes about 10 min to clean using a Filtercharger kit, wait for it to dry, re oil, done.
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5805805
not to too much of topic but before i sold the car i had a k&n typhoon complete cai system and it was wonderful, and i think it was worth the pretty penny that was spent on it, i dont know about power it gave though but it did make a good noise and just made the engine and car a bit more lively. and past about 4000 rpm it sounded very nice and if you tap the accel you could hear a little sucking sound very very similar to a turbo (had been mistaken a few times for one lol) but nothing to douchebaggy like a fake BOV on a NA
https://www.sau.com.au/forums/topic/363696-panel-filters/#findComment-5806301
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
